Prying off a valley pan that’s been glued down with the Right Stuff or similar without a gasket will usually cause you to bend the crap out of the pan getting it off, ruining it in some cases.
The gasket is far more forgiving in that respect and seals just fine using the proper method.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
There is absolutely no need to use right stuff, as I said, GM substituted black RTV, and later on GMS red RTV. I never use right stuff because it is really difficult to remove.
I've taken dozens off in dealerships, as well as my own, and my customers. I guess if you use hammers for tools then you might destroy a valley pan. I've never bent one, but I guess if you use right stuff, you could possible bend one. I've used RTV on all of my race engines, and if anything, a race engine is going to come apart much more often than a streetcar is. In the late 70s and 80s GM used RTV on every engine they made, on all the valve covers and oil pans, not right stuff. Never had one iota of trouble removing engine sheet metal from any of them............
| The Following User Says Thank You to Sirrotica For This Useful Post: | ||
