Originally Posted by rolling money pits
Would the “valve cover gasket” method work/apply in this instance? Adhering gasket to valley pan, then on block side use grease or whatever, to seal it.
I’ve read about that, in the past never applied it, was a careful RTV guy, and of course had weeping here and there.
Or, is the valley pan a different animal in that there’s multiple parts/seams - block and heads - it seals, unlike the VC which has a nice uniform surface it rests on?
I have never personally tried that, using grease. On valve covers, I glue them in the covers with weatherstrip adhesive, just enough to hold them. Then on the head side just install clean and dry. Every now and then a little RTV may be needed if there is a little weeper. The idea of applying grease and sealer in the same area just never seemed right to me. I have however used a little grease on Holley bowl and metering block gaskets in the past. But for the last 20 years or so they have come with an anti-stick coating already on them.
