#41
Old 08-30-2024, 10:51 AM
1qwerty's Avatar
1qwerty 1qwerty is offline
I always just go straight
to worst case scenario(bad habit). I will look and see if the pickup is still where it should be then I guess I can try to pull the pan and check the bypass
Looks like I pull the pan regardless
Thanks for everyone's input
JWB
  #42
Old 09-09-2024, 04:03 PM
1qwerty's Avatar
Smile Fixed
Wanted to thank everybody for their help and suggestions I tried to keep it simple so after the oil and filter change didn't work me , me and my son were about to pull the pan I started it up and with a cold engine nailed it a few times oil psi hit 80
All press hot and run hard
Idle in gear 22
Out of gear 38
2000 rpm 60
  #43
Old 09-09-2024, 05:09 PM
So you blasted out a spec of crap that was holding open the pump bypass.
Now keep your fingers crossed that it doesn’t get in that bad place again.
  #44
Old 09-09-2024, 06:03 PM
1qwerty's Avatar
Hopefully eventually the oil filter catches it
  #45
Old 09-09-2024, 06:06 PM
Lightbulb
A magnetic drain plug wouldn’t be a bad idea.
ID:	639754   Click image for larger version
  #46
Old 09-09-2024, 07:40 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Idle in gear 22
Out of gear 38
2000 rpm 60
Good deal. Iv`e heard of "Italian tune ups" before.
  #47
Old 09-09-2024, 08:17 PM
1qwerty's Avatar
Will do on mag plug
