A friend is building a 75 TA and trying to hook up somewhere around 650HP but drive on street and look stock. He has 9" rearend (3.70) and caltracks already.
He wants wider Rally II wheels but not sure what size/BS to get. He wants to run 275/60/15 on back, maybe M/T street/strip tires. Any suggestions from someone who has experience with this type thing. Thanks for any help.
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
I had 15X8 rally IIs from Wheel Vintiques with 4.5 inch backspace. Had 275s on them and they were close but they fit my 72 Formula. No guarantees. I have stock 15X7 Honeycombs on it now with 275s and they clear and the car is pretty low. The sidewalls are sucked in a little, but I don’t care. Don’t know if that helps you. That setup is on the car in the avatar.
I was going to suggest the 15x8 wheels as well. I have 275’s on them and they fit good
Same here 15x8 4.5 backspacing 275/60/15 tires
74 Formula Below motor destroyed fall of 2023 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet 75 Formula 400 / 4-SPD matching numbers |
I have a pair of Wheel Vintiques 15 x 8 Rally 2's that were custom ordered with 5.25" backspace to centre the wheel in the wheel well of my GTO with 275's and rear disc brakes. When I mocked up the same tires on a set of 15 x 8 Rally 2's with the standard 4.5" backspace, the tires ended up too close to the quarter, partially due to the disc thickness compared to drums.
When I figured out that I needed more backspace, I called and emailed WV and they would not give me the time of day...someone here suggested I call Summit and when I did, they confirmed they could do a custom order for me. This was about 8 years ago, no idea if they still do this. I realize this does not answer your question about F body fitment but thought I would relay that custom backspace was available.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
76 rally 2 15x10 4 1/2 bs with 275/60 stock 10 bolt ,love the look and stability around turns,hooks from a slight dig full throttle thanks to the 273 gear
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
| The Following User Says Thank You to joes455 For This Useful Post: | ||
Use the Tire Rack website to see section widths and corresponding measuring rim widths for the size you want to use. Click on specs and the dimensions are clearly displayed.
https://www.tirerack.com/tires/tires...9xxi9I7oocJ2Sx A 275/60-15 will vary a little in size between manufacturers but I saw one that on a 8” wheel has a 10.7” section width. You might be able to find the exact tire brand with specs that you want on the Tire Rack, it’s a pretty solid tire reference site. So use that overall section width dimension to determine how much room you actually have from the inner fender to the outer fender lip. A straight edge and a tape measure is all you need. You can use a bare 15x7 Rally II wheel to measure off of to help you, mount it on the rear axle and set the car down on the bare rim using a block of wood under the rim. That way the weight is on the suspension and you can measure accurately. Measure a lot, you’ll figure it out with a little effort. I would never trust anyone’s measurements but my own and so should you.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
This is what you want. ^ 15x10" rim. The 275 tire will look suck in on the sides with an 8" rim. They fit much nicer on a 10" rim. I have the BF Goodrich T/A on a 15x10 " rim with 4.5" B.S. IMO Like Bart says, you almost need to do some measuring. I do run a Moser 12 bolt rear-end. I did run the same tire on my 10 bolt rear-end with 8" rims and then moved up to 10" rim, same back space.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. Last edited by chuckies76ta; 09-14-2024 at 06:45 AM. |
If you run a wider tire on a narrow(er) wheel, that 'bulge' takes away from what you can fit, not to mention it's not safe. It is possible for the tire to roll off the wheel. Also, on a dip or bump as the suspension compresses, the bulge can contact the lip and blow a tire.
If you run a 'bulge', you actually can only fit a narrower tire than without a bulge. An option that helps is you can roll the lips, but more prefer not to do that. Several things need to be known before trying to fit the widest possible tire on a 2nd gen F: The 'baseline' wheel size on a 2nd gen F is 15x8 with zero offset. Or, in other terms, 4" back space. (EDIT: or 4.5") Some wheel manufacturers measure width differently, so it's important to know that. The distance to the wheel lip from the rear end flange is closer to the lip on the passenger side than the driver's side. So measure both sides. When doing offset calculations, understand it's not just the fender lip that you need to watch, it's also the leaf. In some cases, the leaf buckle. Tire 'squirm' can make contact even though they clear at stand still. Like around turns. In general, you can't go more than 4" outboard on the wheel due to fender lip contact. That accounts for squirm/tire roll. (and no bulge). So when going to an aftermarket wheel, changes to width should be made towards the inside. On like 74-up, there's also the seat belt bulge that can make contact. Might be '75-up or so. b-man is correct, 'section widths' do vary, and you have to check/take into account. Keep in mind that measurement does not take into account for bulge when running a tire on 'unapproved' widths. You should be able to do a 275/60-15 on a 15x8 wheel with 4.5 backspacing. A 15x9 with 5 or so backspacing would be a better choice though. And, it will depend more so on the tire. That is not taking into account if you added disc brakes to an OE width rear. The Herb Adams VSE catalog (should be able to find one) outlines much of this and is a good reference. Just to say, it is possible to go too wide on a tire. As the contact patch increases, the corner weight gets distributed over a larger area and will not have as much downforce. Just look how 10.5 cars can hook so well. .
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
Thanks for all the input. I'm passing it all on to him so he can figure out what is best.
I know he doesnt want to alter wheel lip. Plenty of power, just has to try to hook it up.
Here you go,10" wide rim 275/60/15 MT drag radials.No way will that lip hit the side wal bulge.
I had 295/50R15s on my old bird with CI 10" rally iis outback if that helps...obvious bit of a rake on the old girl lol
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
Both those cars are way too high in the back, of course they won't hit the lip, you could go to 12" wheels on those and not hit. Those things stick way out past the quarter.
Go ahead and have 4 people in the car and see what happens. .
As HWYSTR455 says. If you jack the rear end high enough, you can put any width tire on the rear. But a 275/60/15 is over 28" tall - taller than the OE tires - that actually fit inside the fender.
Both photo examples look to have 4+" of space over the top of the tires. |
The last set of 275’s I had were Hoosier DR’s and they actually measured just under 27-3/4” OD with just over 11” SW and just under 10” tread on a 8” rim.
After 1500 street miles and maybe a dozen passes at the track they were toast, but man do they hook!
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
Haven't tried putting 2 people in the back ,would imagine it would get closer to the fender,but the op friend is making 650hp and it is important to get the most traction to the ground.Airshocks were swapped out by a lot of owners of these 2nd gen f bodies to get clearance, inwhich even by today's standard its not a bad idear
I use Nitto 555 Drag radials on the street and at the track M/T et pros. I'm currently just using 8 inch wide wheels. A good suspension will help your buddy ..Caltracs and Split monos on rear and good shocks front and back. Also when comparing tires the ET Pros are a big 275/60 tire .
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
| The Following User Says Thank You to ta man For This Useful Post: | ||
As the rear ride height rises, weight on the rear tires shifts to the front tires, and there's less downforce on the rear tires. By raising the rear, you're making any traction issues worse.
From the factory, 2nd gen Fs actually sat lower in the rear than the front. Can you guess why that is? Again, reread my original post: "You should be able to do a 275/60-15 on a 15x8 wheel with 4.5 backspacing. A 15x9 with 5 or so backspacing would be a better choice though." There's no reason to jack the thing up with the correct offset and width. And people did that back in the day because of lack of understanding, and to 'be cool' with the jacked-up backend look. Why not go to the track and look at similar cars that are hooking, see what makes them successful as a guide? .
Yeah tried the 8" wheel with 275/60 MT hooked up good but not as good as the 10"also there is a lot more rear end lateral floating (side to side movement)with the 8".No need to re read a post
My '70 TA pictured here with Nitto 275/60R15 drag radials on the rear.
Rear wheels at the time were American Racing Torq-Thrust in 15 X 8.5 ( p/n 105-5861 -24 offset 3-3/4 backside ) (Since then I have changed to Vintage Wheel Works 15 x 8, 3-7/8 back spacing on the rear and 15 x 7 on the front) Front tires pictured are Firestone 215/65-15 with a 15x6 wheel, however later I changed to a larger 245/60-15 in front for the additional foot print for braking. Rear suspension: Landrum 300 lb/in leaf springs, Edelbrock shocks, CalTracs traction bars, custom subframe connectors https://www.motortrend.com/uploads/s...75&format=webp https://www.motortrend.com/uploads/s...75&format=webp .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 09-16-2024 at 10:54 AM. |
