#41
A thermostat's purpose is to maintain cooling system pressure, The thermostat does not maintain system pressure. The Radiator cap is doing that job.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
| The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
#42
This make no sense to me.
#43
^^^ Lemme reword that. It helps act as a RESTRICTION, which helps aid in maintaining pressure.
And I really don't understand what's hard to interpret about what I said. I'm basically validating the point you made in your post prior to your replies to mine. A cooling system that is efficient and has enough capacity to actually maintain the thermostat's temperature setting will maintain it in closed loop operation (the modulating thing you're talking about). If it's not up to snuff, then the engine temp will be higher than the thermostat rating, meaning the thermostat will always be open as it tries to lower the temperature, but it cannot. This is like not having a thermostat. At that point, whatever temp the car runs at is what the cooling system is capable of maintaining on its own. Every engine is going to run at its own unique, inherent temperature. Compression ratio; power output; water jacket and passage design; ignition timing; valve timing; and fuel mixture all play a role in the temperature an engine will inherently run given. If you have a very good, or at the very least, SUFFICIENT cooling system, then yes, the thermostat will be able to regulate the temperature at or near the thermostat temperature by opening and closing in closed loop operation. However, if your cooling system doesn't have the capacity to allow the thermostat to keep control, your temps will run away and either overheat, or stop at a higher temperature than the thermostat that the engine inherently "likes."
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop ![]() Last edited by nUcLeArEnVoY; 09-15-2024 at 12:49 PM. |
#44
I may have come off sounding somewhat Condescending there. for that I'm Sorry.
#45
1. Static pressure set by the rad cap, and 2. Dynamic pressure created by the water pump moving fluid against "a" restriction. The other side of the main restriction (generally the thermostat, but it could be the radiator) is going to be the suction side of the water pump, with reduced dynamic pressure. What makes this more complex is that there's a hundred tiny restrictions in the cooling system, including but not limited to the small holes in the head gasket, the heater core, the narrow passages of the water jacket as it goes around the cylinder bores, and so forth. #2 is why designers moved away from vertical-flow radiators to cross-flow radiators starting in the '60s. A vertical-flow radiator has the pressure cap on the upper, HOT tank, the entry to the radiator core. If the radiator core gets restricted--scaled-up--the radiator becomes more of a restriction that the water pump is pushing against. This overloads the rad cap especially at high rpm, releasing water into the overflow tank at best, or to the pavement at worst. Either way, there's now less coolant in the system and greater chance of overheating. A cross-flow radiator has the pressure cap on the COOL tank, on the other side of the core. It is effectively on the suction side of the water pump, so the suction side runs at rad-cap pressure and everywhere else has higher pressure due to water pump motion. The cross-flow radiator is generally better at "everything". The thermostat SHOULD be the "main" restriction in a cooling system, even when the thermostat is fully-open. Whether it is, or not, depends somewhat on the condition of the radiator, and sometimes, whether the correct head gasket has been installed. Quote:
Automobile radiators are always undersized compared to the horsepower the engine is capable of. Compare a 400 HP automotive radiator to a big-truck (semi, or bus, or bigass farm truck) with a similar HP rating--the automotive radiator will be tiny. This is because a 400 HP auto engine is rarely run at 400 hp, and when it is, it's generally for short bursts. The big truck 400 hp engine may run at or near full throttle for hours on end. Automobile radiators are sized to easily handle idle and cruise with a little additional capacity, truck and bus radiators are sized to handle WFO throttle. Take a 427 Chevy. The car engines were rated up to 435 hp, they had the usual thermostat and radiator-hose. The 427 tall-deck truck engines had maybe half that horsepower, they had governor-carburetors to limit RPM, and they had TWO thermostats of the same size and capacity as the single thermostat in the car engine, and a monster water pump. Look at the "cock and balls" thermostat housing on one of them--two rounded thermostat areas, plus the GIANT snout for the huge-diameter upper radiator hose. (Photos shamelessly stolen from the Internet. https://www.tradecraftspecialties.com/bbckb#Topic4 Quote:
You toss an electric fan into the mix, and now the coolant temperature is dependent on both the coolant thermostat rating, AND the cooling-fan thermostat. My '92 and '93 Luminas with electric fans don't have the fan come on until 210 degrees. I think the second fan comes on at 220. Quote:
You have a 180 thermostat, so at 200 degrees, that thermostat is almost certainly fully-open and no longer controls the engine temperature. You have NO way to increase coolant flow through the radiator except to add RPM (fan and water pump speed) and/or vehicle speed. Your cooling system needs improvement, or your engine needs tuning/friction reduction. (Often a matter of more spark advance, (vacuum advance) richer cruise air/fuel mix, lower-tension/thinner piston rings to reduce friction, verify piston-to-bore clearance for friction reduction, lower exhaust restriction/block exhaust crossover in intake manifold, and so forth.) Quote:
| The Following 4 Users Say Thank You to Schurkey For This Useful Post: | ||
