Old 09-19-2024, 11:23 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
Default Give me a good reason
As I get closer to my 74th birthday next month I am facing some decisions, My 67 needs a little work and I could probably do it, but I am not sure how to do one thing.
When I tore the car apart I bagged and labeled all the small parts. They went with the body when it was mated back to the frame. Somehow the radiator core support shims got lost so they didn't get installed. I knew there were 2 or 3 on each side, I think, So the front end was all tightened down and the hood fender alignment at the front of the hood is about 1/4" off with the hood sticking up. And the gap across the front of the hood narrows t the center to almost touching the header.
I also think this is responsible for my tires rubbing the outer top edge of the wheel well. While fixing this it won't be a problem t replace the radiator
So that is one problem and probably the biggest but there are more smaller ones. The convertible top switch was installed on the far right edge of the gauge panel when it should have been put on the left. As a result the switch broke apart from the stress of the wiring harness. I now run the top with a heavy duty toggle switch bolted through the bottom of the dash.
Anther gremlin is the heater fan speed switch. I had two burn up before I found the loose connection further down the wiring harness.
But, physical limitations won't allow me to crawl up under the dash to get to the switch, which is held on by two quarter inch screws that disappear as soon as you loosen them.I know because there are 6 of them somewhere in my dash.
I can and do drive the car as is being careful when I turn a corner, but I would love to know how to figure out how many shims I need. I no longer have anyone locally to give me that help. All my car buddies have passed on.
Which brings me to car number two, my 1950 Pontiac Streamliner.
It is a project car that I work on when I get the desire. I can legally drive the car but I don't for safety reasons. Brakes are new and bled, but the pedal is soft. Engine runs with all new accessory parts and trans works good.
It needs front floor pans and a few dents knocked out.
Then there is the boat! I bought it as incentive for my son to quit smoking , but he says he can't. I figure another $500-$750 will get everything I need to finish it so I am putting what time and energy I have in it,
The last 6-8 weeks have been hard on me physically and I am beginning to wonder if I have what it takes to get any of them done.
I think it would be a lot different if there was one old guy around that shared my interest , but there aren't.
well, now that I have got that off my chest I will go to bed , I have to make a 2.5 hour drive one way to pick up a piece for the boat!
The Following User Says Thank You to fyrffytr1 For This Useful Post:
Old 09-20-2024, 05:48 AM
nas t eh nas t eh is offline
Is there a car club around? It’s hard to make new friends, but bringing your car to a meeting or a show and shine would be a place to start.
73 T/A 455, 4speed
Old 09-20-2024, 05:58 AM
I’m no body man, hopefully someone who is stops by with a better answer, but I think the shim issue is a trial and error problem at this point. Buy more shims than you need.(since you don’t have the old ones) and install two or 3 per side for a starting point. It will either be good or you will have to add or subtract 1 or 2.
73 T/A 455, 4speed
Old 09-20-2024, 07:11 AM
Andre's Avatar
Andre Andre is offline
Just keep enjoying the car as a it is. Work on the 50 as time, strength and inclination allows. I have guys here that are 10 years older than you still working on these cars... a little bit at a time.
The Following 3 Users Say Thank You to Andre For This Useful Post:
Old 09-20-2024, 01:49 PM
I doubt that a few shims under the core support are what’s bringing the fenders down enough to cause rubbing.
Going one tire size smaller is probably the easiest way to solve this issue.
Putting shims under the core support now means realigning the front sheetmetal. While it would be a nice thing to do it’s opening a can of worms and you may end up chipping the paint during the process.
Old 09-20-2024, 04:11 PM
bdk1976 bdk1976 is offline
x2 - BTDT and have the paint chips to prove it (and I'm still not totally satisfied with the alignment)!
The Following 2 Users Say Thank You to bdk1976 For This Useful Post:
Old 09-20-2024, 05:02 PM
Never give up as long as you have the will and the interest.
I’m sure there’s a shop somewhere not too far away that can troubleshoot and fix the soft brake pedal.
A hot rod shop that has experience replacing sheet metal body panels should be able to handle replacing the floor pans without costing you a fortune. Shops like these usually don’t shy away from doing brake work on ancient automobiles so maybe they could knock out this one too.
At a certain age it’s a good idea to budget and farm out a few of these more difficult projects that you can no longer handle physically. I realize most retirees are on a fixed income and affordability can be difficult.
Sell the boat without hesitation if you’re not really into it, even if you have to take a loss. Use your energy and money for the things that truly interest you and forget about the rest. Boats are money pits even worse than old cars.
Old 09-20-2024, 10:18 PM
1965gp 1965gp is offline
I agree- sell the boat and pay someone to fix the dash issues on the 67. I would probably leave the sheet metal alone. How bad is the rubbing.
Where are you located?
Old 09-20-2024, 10:26 PM
Leesburg GA.
Old 09-21-2024, 06:41 AM
sdbob sdbob is offline
Try to logically and patiently figure out the best way to solve your problem to your satisfaction.im 76.Words I know,however if I walk away then sit and think this usually helps me to solve the problem at hand. Yes I do ask friends in our Pontiac club. As I age I still get in a hurry. I remember when I could do this or that !!
The Following User Says Thank You to sdbob For This Useful Post:
Old 09-21-2024, 01:53 PM
fyrffytr1's Avatar
I want to finish the boat. Then I will decide whether to keep it or let it go. It is a 16.5' Tracker aluminum boat with a 25 hp Evinrude motor. The motor runs like a top and it has a hydraulic jack plate that is worth what I gave for the boat,
The trailer has been completely refurbished and all the minor leaks in the boat have been repaired. I have a new stick steer system to replace the old corroded one. Basically, I lack reinstalling the side and bottom sheet metal and then installing the carpet. I am closer on this project than any other.
I have had boats before and always enjoyed them.
Now, as to the GTO. the right front tire rubs where the top inner fender bolt head sticks out. It rubs on turns when there is a dip in the turn. 99% of the time it is on a right turn. I removed the bolt but the tire still rubs on turns when the suspension flexes.
The left front tire rubs in the same spot, but it takes a lot more weight or stress to make it rub in a left turn.
All the front suspension parts were replaced about 15 years ago and I have driven the car less than 5,000 miles since then.
Old 09-21-2024, 01:58 PM
fyrffytr1's Avatar
B-Man, thanks for the reply. Actually, there is not a hot rod shop in my area. I would have to trailer the 50 at least 100 miles to get work done on it, not counting the waiting period to get it done.
I wish sunny so-cal was closer! Sunny so-ga is a desert when it comes to shops that work on old cars.
Old 09-21-2024, 02:05 PM
fyrffytr1's Avatar
I am a member of our local car club. Unfortunately,the car culture in my area is Is almost non-existent. Most of the younger guys are into the hew hot rods and the few older guys are in the same shape as me.
I did talk to one of them and he said he would drop by one day and look at the 50 floor pans.
If that doesn't pan out I may consider tacking them in and fiber-glassing over them. I know that is not the "purist" way and I would never sell the car without revealing what has been done, but I do see this as an option.
Old 09-26-2024, 08:56 AM
I recently turned 67, and I'm definitely losing my motivation to work on old cars. I was hoping to restore 5 cars once I retire. I've worked about 4 - 5 years longer than intended, so I'm definitely going to be scaling back my plans for my retirement years.
Old 09-26-2024, 10:33 AM
Pontiac Performance Author
A quick fix might be to install air conditioning shims under the springs for a little more ride height.
Old 09-26-2024, 01:03 PM
fyrffytr1's Avatar
I have the A/C coil springs in it now. My car is factory A/C.
Old 09-27-2024, 01:45 PM
ta6point6's Avatar
What I like to do is look at YouTube videos and that usually gets me motivated. I pick one thing that I have to do on the car and watch a few videos. There is always someone on there that has found a way to do it smarter not harder. Of course the brevity of the video does not always equate to real world time that is spent working on the vehicle but does provide some helpful hints. I recently watched a video on swapping the clock spring to add a heated steering wheel to Avalanche, made it so much easier
going bandit-Reynolds style
Old 09-27-2024, 02:40 PM
Keith Seymore's Avatar
Following along.
(I'm 63 but had a rough year car hobby wise).
K
'63 LeMans Convertible
'63 Grand Prix
Old 09-27-2024, 02:48 PM
Even if you have to trailer the car 100 miles or so it’ll be worth it to have a reputable shop handle the work.
I hauled all of my 421 engine in pieces to someone who’s much more experienced than myself living 110 miles from me. He handled getting the machine work done at his trusted local shop along with doing the painting, assembly and break in before I picked it up several months later.
Otherwise it would have taken me forever or worse yet the engine build would have stalled out and would still be waiting to get done. I don’t have the tools, mindset, clean workspace or enough engine building experience to have ended up with the perfect running leak-free engine I’m now enjoying.
Git’er done, life’s too short.
Seriously if you’re not physically able or lack the proper tools, energy or ambition this is the way.
Again on the tire rub, just buy one size smaller front tires, don’t raise up the front of the car. The old front tires can be either used in the rear later on or sold.
Old 09-27-2024, 09:34 PM
fyrffytr1's Avatar
Following along.
K
I've had a rough year health wise. Covid, then food poisoning kept me down most of August. Lower back pain is constant. I guess I shouldn't bitch about it. I could be a lot worse off.
