Old 05-20-2023, 05:28 PM
jpg69bird jpg69bird is offline
Default Thrush 89021
Planning on installing the Thrush 89021 on a 2nd gen Trans Am with 2-1/2" Ram Air Restorations exhaust manifolds RM-2-OS.
Do the 3 bolt flanges that come with the exhaust system fit these manifolds, or do I need to buy the FL-1-OS oversize flanges from them?
69 Firebird Conv, 350 HO w/3 on the tree swapped to Tremec 5 Speed - Sold
72 GP, 400 Auto - Sold
09 G8 GXP M6 Orig Owner - Sold
76 Trans Am 455, 4 Speed - Current
Old 05-20-2023, 08:55 PM
ID67goat's Avatar
ID67goat ID67goat is offline
The 89021 is meant to be used with headers so you will need to get head pipes and the proper flanges for your manifolds.
Old 05-21-2023, 10:42 AM
Thanks ID67goat. I planned on using the downpipes from RA. I guess I'll need their flanges.
Old 09-21-2024, 02:58 PM
DanC's Avatar
DanC DanC is offline
Question
Originally Posted by jpg69bird View Post
Planning on installing the Thrush 89021 on a 2nd gen Trans Am...
Did you ever install this Thrush system? If you did, how do you like it?
I'm wanting something that sounds quiet at cruise inside the car, rather than the Flowmasters I have now that are too loud.
1968 Firebird Convertable - my original HS car!
1978 Firebird Esprit "survior"
1930 Ford Model A Coupe .. (original)
1994 Buick .."TowMaster" ...woody wagon
Old 09-21-2024, 08:19 PM
Hey DanC, it's still sitting in my basement. Had other issues I wanted to fix first. Should get it in this winter.
Old 09-22-2024, 05:06 PM
DanC's Avatar
I definitely know how that goes, if it ain't one thing, it's ten others Thanks for the reply.
Old 09-23-2024, 11:11 AM
Ive used that 89021 system before and I like it for several reasons.
One being that it still uses the standard in and out bends that go into the transverse muffler which means you can swap that muffler with any other standard transverse style muffler. Can't do that with the pypes sgf70 setup as it uses their own in and out configuration.
Because of that I've often swapped the thrush muffler that comes with the 89021 with a dynomax ultra flow transverse, it bolts right in.
If you don't mind aluminized pipe and an h instead of an x cross over, it's a nice system. Very quiet with the thrush muffler and all mandrel bent.
https://youtu.be/XqEydRRRwqE
Old 09-24-2024, 11:21 PM
DanC's Avatar
Thumbs up
Ive used that 89021 system before... Very quiet with the thrush muffler and all mandrel bent.
Thank you for the reply. I was hoping to hear from someone who has actually used it and what their thoughts were. I like the idea of it being quiet, especially going down the interstate.
