#41
As I recall what was the 360 hp motor in the GTO was down rated to 345 in the Firebird by means of limiting the secondary throttle opening, but that being the case 345 Hp will not feel like a Turd, nor will even 300 hp.
Oh, and if it has not been posted yet confirm your firing order.
#42
A couple of people have asked. So why not do a cranking compression test? Stan
#43
Cam timing is retarded.
Triple Black 1971 GTO |
| The Following User Says Thank You to NeighborsComplaint For This Useful Post: | ||
#44
Mystery solved. I picked up a TDC piston stop tool. Seems the balancer has slipped/is bad.
According to the TDC tool, my balancer reference mark is off by about 11 degrees. Top line is original mark, lower line is correct according the the TDC tool. If I’m not mistaken I’ve been running 10-12 degrees retarded.
| The Following 3 Users Say Thank You to Lidpainter For This Useful Post: | ||
#45
Excellent news - please update after you swap in a new balancer.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#46
Good news to hear!
That much retard is right on the edge of the motor backfiring when you mash the throttle which would have been a more definitive clue to your issue assuming your firing order was right. Now get a new balancer and go make some rear tire smoke.
#47
Right on!
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
#48
you can go by the new mark and time it presumably correctly and enjoy how it is supposed to run while waiting on new part (sanity check)
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
#49
You might want to take advantage of this service if your balancer is not cracked in the keyway area.
| The Following User Says Thank You to steve25 For This Useful Post: | ||
#50
Well that could've gone bad if it was 12 degrees advanced, I smoked all 8 cylinders on a fresh engine all because they didn't mark true TDC on the balancer and it was 4 degrees advanced.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
#51
Who's they?
In that case how did you even set the initial advance on the motor?
#52
That's a very small detail that is commonly never checked.
Easy fix though. Even with a new balancer I'd still verify the mark and remark new balancer if necessary (usually is) as I find new stuff is even off a couple degrees. |
#53
My gut is telling me the cam timing could be retarded. What does the vacuum gauge say? Where are things at TDC? Have seen timing chains installed off a tooth give the same symptoms. Engines that should run strong run like yours.
Jeff |
#54
Stan
