Old 10-20-2024, 10:26 AM
PAUL K's Avatar
PAUL K PAUL K is offline
You might want to look at a TrueTrac over the spool. It will make everything easier and should be plenty strong for your power level and weight. I'd also investigate using the 30 spline version (28 stock) and take advantage of the bigger axles just Incase you up the power level down the road.
IMO a Nitrided SFT camshaft with quality lifters is the best option for reliability for a dual purpose vehicle.
Go fast, see Elvis!
Old 10-20-2024, 10:29 AM
mrennie's Avatar
mrennie mrennie is offline
Thanks Paul. I had planned on 30 spline axles anyway so will look into the TrueTrac.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
