Old 11-06-2024, 11:35 PM
gto4ben gto4ben is offline
A clamp-on DC ammeter would be more helpful in tracking down a parasitic current leak. Since it appears you don't have one, use the ohmmeter setting.
Assuming the alternation is the original 10DN type, disconnect all the cables connected to the BAT terminal and disconnect the F-R connector. With the ohmeter positive lead on the BAT connector and the Negative lead to alternator ground, see if the reading is > 100KΩ. (Note that there is a 0.5uF capacitor in the alternator and it may take some time to stabilize.) If lower, one of the alternator diodes or capacitor is leaky.
With the BAT terminal still cleared off cables and the F-R connector removed, set the ohmmeter positive probe on the R-terminal and the negative probe to alternator ground. This checks the diode powering the regulator field solenoid. See if the reading is > 100KΩ.
The Following User Says Thank You to gto4ben For This Useful Post:
Old 11-07-2024, 03:34 PM
richardk's Avatar
richardk richardk is offline
Yeah, I probably should have sprung for the more expensive meter but at the time I didn't think I would have much use for it.
With BAT terminal and F-R connector both disconnected meter reads 193.1 KΩ between BAT and ground. Between R and ground, with everything still disconnected, it reads 142.3 KΩ. So, what is that telling me. Sorry if I seem a little dense here; like I said, not an electrician.
I certainly appreciate the help, thank you.
"I fishtail through the lanes, and I make my tires squeal.
Power at my feet, and glory at the wheel.
I wind the windows down, let the wind blow through my hair.
God knows where I'm goin' to, but me... I don't care."
