Old 10-20-2024, 06:21 PM
rerunss rerunss is offline
Update?
  #162
Old 10-30-2024, 04:48 PM
darbikrash darbikrash is offline
The first in-car install in a ’69 GTO has been completed by the owner and the results are very good. He is very happy with the results, and will likely put this car on the rollers for some final dyno tuning. I've asked him to post some first hand remarks on this forum when he gets the chance.
I rode in the car before the tuning was complete, and the power is most impressive.
Here are some of the highlights:
- No hood clearance problems.
- No under hood clearance issues, power steering box, exhaust, etc. all cleared.
- No real issues with the supercharger/intercooler/front drive install in general, this part went pretty smoothly. Some shimming was necessary for one of the idler pulleys to insure alignment, but other than that, no issues. The idler pulleys are designed to take shims to allow for a perfect fit for every car.
- There were some issues around the EFI installation, as is typical when converting any carbureted car to full sequential EFI.
o The crank trigger and cam signal setup is a little tricky when using the front mounted crank trigger instead of the dual sync trigger. Once setup correctly, there were no issues.
o This particular system has 8 separate coils for individual spark trim and individual cylinder fuel trim. These coil systems have very high voltage, so the grounds are super important. Once the grounds were sorted, there were no issues.
Some takeaways from the install:
- It was helpful to have a radiator with the inlet and outlet both on the passenger side. It can be done with a traditional driver side inlet hose but packages much more nicely with both hoses on the passenger side. Cold Case sells a reasonably priced radiator with both fittings on the passenger side- and one was used here.
- The supercharger part of the installation was fairly easy and everything fit pretty well with no rework of any parts necessary, the EFI part was more difficult.
- The engine runs very smoothly, idles nicely and is a very tractable street engine with plenty of power under boost.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
The Following 10 Users Say Thank You to darbikrash For This Useful Post:
  #163
Old 10-31-2024, 12:07 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
That's great news!
  #164
Old 11-09-2024, 02:26 PM
Patrick Fahey Patrick Fahey is offline
I’m looking any information for my 1970 GTO convertible project I just purchased
  #165
Old 11-09-2024, 05:25 PM
Welcome to PY
Go to the 70-72 sub section and create a new thread there.
With specific questions.
Being 0 post count (lobby posts don't count) you might need to make some other comments in the various other sub sections of the forum first, before the software allows you to make a new thread topic.
  #166
Old 11-09-2024, 07:42 PM
71 Goatman's Avatar
71 Goatman 71 Goatman is offline
Just wondering where you landed on boost, how many psi? Is the plan to run this engine on 91 pump gas?
Thanks!
71 Goatman
Hot Rods & Horsepower.......A diease for which there is no cure.
71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming
  #167
Old 11-10-2024, 01:20 AM
Thanks!
This is intended as a pump gas application. Boost depends on many things, most importantly what pulley size you run, and how well do the cylinder heads flow.
The in-car blower test is around 10 psi using stock unported cast iron 4X heads and 91 octane.
The Following User Says Thank You to darbikrash For This Useful Post:
  #168
Old 11-10-2024, 05:44 AM
I’m waiting for price and availability. But, I’ve got the hots for a blower, I don’t know how long I can hold off.
  #169
Old 11-10-2024, 02:59 PM
Supercharged GTO on the road. It is pretty surprising as there is virtually no noise or whine from the supercharger, unlike many other packages that have a loud and distinct whine. This is at least in part due to the helical bevel drive gears which are much quieter than straight cut spur gears.
Click on image to play video:
The Following 4 Users Say Thank You to darbikrash For This Useful Post:
  #170
Old 11-10-2024, 03:25 PM
Can't get it to play by clicking on it.
Just stays as a still image.
It's a .jpg file
  #171
Old 11-10-2024, 03:58 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Very nice. Great packaging into the engine compartment.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
  #172
Old 11-10-2024, 04:15 PM
tom s tom s is offline
I was at breakfast with the guys this AM.Bill drove the GTO today.
The Following 2 Users Say Thank You to tom s For This Useful Post:
  #173
Old 11-10-2024, 04:18 PM
johnta1 johnta1 is online now
Right-click on pic/video above and open in new tab.
Or here is the link it goes to:
Blower
The Following 2 Users Say Thank You to johnta1 For This Useful Post:
  #174
Old 11-10-2024, 05:11 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
very impressive. nicely done
  #175
Old 11-10-2024, 07:24 PM
242177P's Avatar
242177P 242177P is offline
It's a .jpg file
Not a .jpg, might be your OS or phone?
https://live.staticflickr.com/video/...ODUiLCJ2IjoxfQ
The Following User Says Thank You to 242177P For This Useful Post:
  #176
Old 11-10-2024, 08:00 PM
It might be my tablet or the chrome browser.
None of the 3 links posted will work. lol
Johnta1's wants a passcode - and yours hits an error page.
The original just shows me a .jpg file/picture.
ht tps://live.staticflickr.com/31337/...e6b20f08_b.jpg
I'll catch up with it someday if it works with an iphone #8 .
  #177
Old 11-10-2024, 08:21 PM
242177P's Avatar
This is a very temporary link, maybe it'll work?
https://s4.ezgif.com/tmp/ezgif-4-3cb25ae290.mp4
  #178
Old 11-10-2024, 10:12 PM
I was too slow. But thanks for trying.
  #179
Old 11-11-2024, 08:10 AM
Looks awesome! I’m going to try to hold off until you release it to everyone else.
  #180
Old 11-12-2024, 01:27 PM
Fastmonty's Avatar
Fastmonty Fastmonty is offline
Default Wow! Officially added to my To-Do List
Bill just called me. I think we need to talk... Will DM and email you.
Mike "Fast Monty's Garage" on YouTube
Keep up the great work!
The Following User Says Thank You to Fastmonty For This Useful Post:
