Not trying to make it a road race car or anything so I'll probably just stick with rubber. Now I'll just see if there's a quality kit out there for it.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
What's in it now that you are replacing? And do you have aftermarket springs?
Those two questions will give you a more accurate recommendation. If you are using factory springs, and you switch to a more easily articulation suspension setup, the factory springs will be too soft. (and you will notice it) Poly bushings are more free-articulating bushings than OE, there are no 'teeth' on the inner sleeves, so you don't have to worry about tightening them while the car is loaded (on the ground). OE rubber bushings have the inner sleeve actually bonded to the rubber. That provides a certain amount of 'load reduction'. When you tight the bushing, the 'teeth' bite into the frame mounts, and resist a certain amount of twisting. In later 2nd gen F-bodies, a harder durometer bushings was used as part of the WS6 handling package, which were tuned to the springs & shocks (rate & valving). No one ever complained about harshness with those. Free-articulating suspensions usually benefit from different shocks than OE type. Most have rubber body bushings, so I honestly can't understand how people can say the ride gets 'harsher', it's almost unmeasurable. But I think it's more due to the fact that a more free-articulating suspension makes it more 'sensitive' to shock selection (and spring). And THAT is what I believe people related the 'harshness' to. (And not the bushings themselves). .
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' Last edited by scott70; 11-26-2024 at 11:42 PM. |
