This is why the close ratio muncie was always (for 1970 & prior) associated with a lower gear set; Only with the options shuffle for the 1971 model year did the close ratio not always require a lower gear set. Does that shed some light on to the situation? You made me do some searching - nice car!! LINK
Some with just HD Radiator Some with HD Rad & Perf Axle Using this Formula in comparison does seem like it's very possibly an indicator towards the TA's also. You worded that very well. Just need enough 3.73 Van Nuy cars with accompanying Bsheets and Invoices to nail that to the TA's. But it has credibility in context. |
This was a mixed bag in '70. Very early production M21 cars like the subject of this thread seem to have not included the cost for the Performance Axle on the invoice, while later cars did. The extra charge appears on all the M21 Formula invoice copies I have for cars with Norwood VINs beginning 107xxx (late March). See example invoice.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
| The Following User Says Thank You to keith k For This Useful Post: | ||
interesting.
My sales book has an issue date of February 26 1970 - so it's presumably the first issue for the 1970 model year to contain the "1970+" Firebirds; I had assumed from how this book reads, that the '37R' axle was included in with the option cost - not an additional required option like it reads for #361. So it's safe to assume that '37R' = #368 ?? Maybe PMD issued an update of sorts requiring #368 be an added cost option if #358 was ordered?
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 11-28-2024 at 01:28 PM. |
Here's what I found:
Code - 348 UPC Code - L74 Available Formula; Standard TA 400 ci Ram Air V8 4BBL (RAM AIR III) Ram Air III: Not available with 2 Speed Auto Trans (352), Turbo Hydramatic Trans (359), or Mountain Performace Axles (754) Code - 347 UPC Code - LS1 N/Available Formula; Available TA 400 ci Ram Air V8 4BBL (RAM AIR IV) Ram Air IV. Not available with Air conditioning (582) ----------------------------------- Code - 361 UPC Code - G80 Standard - TA Safe T Track differential Requires performance axle (368) axle ----------------------------------- Code - 368 UPC Code - G90 Performance Axle ----------------------------------- Code - 358 UPC Code - M21 Available Formula; Available TA Close Ratio 4 Speed Manual Transmission with Hurst Floor Shift Requires Safe T Track Differential (361). Formula 400 with Peformance Axle (368) - $195.36 Trans Am with Performance Axle (368) - No Charge -----------------------------------
Found this (for GTO but probably similar):
(not sure I have a clearer pic) (at bottom left) Axle -Sales Code 37R is 3.07 ; UPC is GX1
