I bought my ‘55 a few months back. I decided to do an oil and filter change on it this weekend as I’m done driving it for the season now.
So I drain the oil and drop the filter housing and drop in a new canister filter. Manual says 6 quarts with a filter change. I’m showing at least a quart and a half low after firing it up and letting it sit awhile!? So is the manual wrong or did someone replace the dipstick with the wrong one? As far as I know the engine is the original 287. It may be hard to see, but the oil is just at the very tip of the dipstick. Any ideas?
63 LeMans- 69 400 w/ original transaxle. 2.69 gears. 55 Catalina 62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
I vote wrong dip stick.
I checked my 1955 Chiltons and it agrees with your six qt capacity. James Q
James Quayhagen 1963 Bonneville Safari - Nocturne Blue, 4-speed - SOLD |
| The Following User Says Thank You to jamesq For This Useful Post: | ||
OK. So does anyone have a original’55 dipstick they could measure from tip to the seating stopper?
I mean if it was a quart quart off I wouldn’t worry about it, but almost 2 quarts? Plus, the way it is now, if it gets a little low, it’s not going to be readable on the stick, so I will have no idea how much to add to top it off.
Place an ad here for a dipstick.
Until you find one just keep putting 6 quarts in it and just check the oil level on that stubby stick more often. No way does that little 287 need more than 6 quarts total with the filter.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
55-58 Pontiac and 55-58 GMC (Pontiac) V8 engines used the same part number 518006 oil pan. The GMC Maintenance Manual calls for 5 quarts plus one for the filter.
the 57s used 2 different dipsticks, so there is that.
"At no time did we exceed 175 mph. Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Yes, A/C cars had one (and a longer tube) and non-A/C had a shorter one.
I still wish I could find someone with an identical car so that they could measure from the tip of the dipstick to the cap that seats against the tube.
