Old 12-11-2024, 05:11 PM
cdrookie cdrookie is offline
Originally Posted by Kenth View Post
Some folks in the "Race Section" with locked mech advance uses a breaker switch on the feed wire to the coil and flips it when the starter got the engine spinning.
Money saved may buy you new tires or a better exhaust system.
I thought about that, be a good anti theft device also, but I really like the features PI built into these distributers. Besides, the only thing I need is a whole new engine, and I can still use the distributer with it.
Old 12-12-2024, 11:05 AM
fastekibeast fastekibeast is offline
2 year in a my GTO no issues.
Old 12-12-2024, 02:04 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Curtis and I installed the PI distributor in our cars several years ago and we love it. Easy to set up any number of advance curves to try out at the track and for street driving as well. This includes vacuum advance which doesn't actually need vacuum but the dist. will sense a vacuum signal if you have the hose connected to a port and then whatever curve you have stored in the dist. will be activated. A great feature for street driving verses the track.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
The Following User Says Thank You to prostreet64 For This Useful Post:
