I have run a little over .500 lift with steel 1.6 rockers on stock iron pushrod holes.. you should be good from my experience even iff the HS 1.5 is closer to 1.6
parallel to this is you need to know if you have valve spring retainer clearance from top of valve guide and seals for your lift
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
