This is the GM (Chevrolet) Performance Pontiac RAIV camshaft #12364044. Last time i checked it was the Crane "blueprint" series camshaft stamped "968".
https://www.jegs.com/i/Chevrolet-Per...64044/10002/-1 There is also a GM (Chevrolet) Performance Pontiac H.O. 068 cam #12364043. Crane "blueprint" stamped "878". https://www.jegs.com/i/Chevrolet-Per...64043/10002/-1 |
| The Following User Says Thank You to Kenth For This Useful Post: | ||
Crane supplied the "GM Performance" camshafts. One popped up here recently in the classifieds section
It's been a while since I bought a RAIV but I went through
Auto Zone and then it was only around $125.00. Don't remember how long it's been though. Try them and see. It was a melling cam. GT |
Just checked at AutoZone. SPC-8 is $295. Ouch.
Anyone ever run the Edelbrock 7157 041 cam? I was pleasantly surprised to find one of these with some parts that I bought a few years ago.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
That cam was in my engine when i got the car over 10 years ago. It vent flat abot 2 years ago, and i pulled the engine an added a topend kit and converted to rollerc am with same specs. I have no other flat tappet to compare it against, but for me it ran ok, and hard a bit of a lope to it, ok vakuum.
Murphy's law - "Anything that can go wrong will go wrong". -469 ,Butler 310+ Eheads, Hurricane intake portmatched by butler, Butler roller 230/236 @0.50 112 LSA, Johnson lifters, pypes 2 1/2" exhaust, 3.42 yukon duragrip lsd, holley sniper efi, hyperfuel efi tank +++ |
I remember people in the late 90's buying that package and using it with decent running cars for the time. Not even sure Edelbrock still sells that as a package deal or not. |
I have the info on the Compcams RA4 cam that went flat during the break in. The flat lobes are right below the caliper in the photo.
The width of the base circle was the narrowest I have ever heard of .506”. The cam is about 3 years old. What is most suspicious is where CWC is cast into it. The lettering does not look like an old molding that has been used thousands of times that you can barely read. It looks clear, like it is new. It looks very suspicious to me, like something you might see from off shore stuff, at very least that is from a new mold. I’ll let you be the judge though, here are the photos of it. Last edited by Jay S; 12-29-2024 at 10:30 PM. |
A cheap copy perhaps? I wouldn't be surprised.
