Old 01-02-2025, 11:30 AM
Originally Posted by scott06 View Post
the volume of brake fluid to move a caliper piston vs a wheel cylinder is what drives the change in Master Cylinder bore diameter
Not true.
A caliper piston while having a much larger surface area only moves a small amount. A drum cylinder moves quite a bit. so the actual volume is almost the same - at least for GM's of our era...
The reason a disc master has such a large reservoir is as the caliper pad wears that much more fluid is pulled into the caliper to make up for the piston travel.
Old 01-02-2025, 11:46 AM
scott06 scott06 is offline
Not true.
from master powers tech FAQ page -https://mpbrakes.com/support/faqs/?srsltid=AfmBOooCqQvljLczun_CETtwTACaghY1XXgEzKSvB vQ9iia5jNLqFZU-#1656435684989-5ec775fd-ea5a
not the greatest snip but you get the idea
Name:	MAster power.jpg
Old 01-02-2025, 11:53 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
Ill defer to the experts if Im wrong, but Im not sure that 10lb residual is accurate for the masters most of us are talking about here.
From what I understand the necessity of the ~10ish pound residual pressure valves (or 2 for disc setups) is aimed at 50's and older vehicles where the master was mounted below the floorboard. When you have the master high on the firewall I think that removed a lot of the need for high pressure residual valves. Drum masters meant for firewall installation may have some residual valving depending on the application, but I don't think they have 10 lb valves.
Old 01-03-2025, 04:07 AM
That is correct from what I have seen. Very few master cylinders from the mid 60's on had integral residual valves - and those were usually Mopars.
Old 01-03-2025, 10:46 AM
Makes sense, certainly the comment on MP page is generic.
Would certainly think unless you really know what you are doing most of us would be better getting a kit vs trying to piece it together.
