Old 01-02-2025, 06:54 PM
Tom Pugh Tom Pugh is offline
Default Mini starter for '73 455
I need a good mini starter for a '73, 455, auto with stock flexplate. The Powermaster I tried did not work out. It interfered with the flexplate regardless of shimming attempts. What are you guys running?
Old 01-02-2025, 07:41 PM
64speed's Avatar
64speed 64speed is offline
Robbmc
Old 01-02-2025, 07:51 PM
Scott Stoneburg's Avatar
I've used a Power Master on a few motors, what was the issue you were having?
Old 01-02-2025, 07:52 PM
i82much's Avatar
i82much i82much is offline
i feel like i had a 9610 that didn't fit so i went with a 9510 that worked, or maybe vice versa. can't remember.
Old 01-02-2025, 08:13 PM
jhein's Avatar
jhein jhein is offline
I tried a 9410 that didn't work but the 9510 did. But I had a clocking issue, not a shimming issue.
Old 01-02-2025, 08:45 PM
When the pinion is pulled out to measure clearance the flywheel teeth literally hit the pinion causing interference and jamming. Needs at least .020 more clearance to move the pinion away from the flywheel
However, the starter mounting block has no accommodation for moving the starter laterally.
Old 01-02-2025, 10:36 PM
graygator graygator is offline
CVR 5311 on a 74 455 auto.
Kent R.
Old 01-02-2025, 11:05 PM
Dragncar Dragncar is offline
I have had a Summit starter on my car forever. No troubles.
Old 01-02-2025, 11:47 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
Same, I have a Summit mini starter that's been on the car for about 8 years now, and I bought it second hand. So I don't know how many miles it had on it before that.
Just here recently it had a couple of instances where it didn't spin when I turned the key the first time. Honestly it might be wiring not the starter. But its been so good to me I wouldn't hesitate to replace it with another Summit starter.
I love RObbMC. I just bought some bellhousing alignment pins from him. But we all operator on budgets and have the pick the battles where we buy the more expensive parts. Ill stick with the house brand starter that's proven its worth.
Old 01-03-2025, 04:41 AM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Which Powermaster did you try? We have used the Powermaster XS 9510 and it worked excellent on a 1979 W72 400 in a Trans Am, but it was a 4-Speed car. It didn't even require any shims, it came out perfect without any.
1978 Trans Am
Pump Gas 461 Stroker
Old 01-03-2025, 10:31 AM
78w72 78w72 is offline
X3 on the summit mini, have one on a 10:7 467 stroker for 10+ years, no issues at all with starting power, reliability or install/fitment.
Not sure which part# it is but summit mini starters are supposed to be reboxed powermasters.
Old 01-03-2025, 10:39 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I've had great luck with the Powermaster 9510 on multiple engines. If you're talking about front to back clearance there is a ring you can use to get more distance between flywheel and pinion. I can take a pic later if you want.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 01-03-2025, 10:43 AM
joes455 joes455 is offline
Summit here also 20yrs
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 01-03-2025, 10:47 AM
track73 track73 is offline
I like the RobbMc because you can clock it in any direction. I clocked mine so the solenoid is facing down.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 01-03-2025, 02:03 PM
the front to back clearance is good. I used the spacing ring you mentioned to get that set. My problem is the ring gear teeth is bottoming out between the pinion teeth. I don't know how to get clearance between them.
Old 01-03-2025, 05:55 PM
BLUE TA's Avatar
BLUE TA BLUE TA is offline
hi, summit for 8 years. set the pinion clearance and good to go
Old 01-03-2025, 06:04 PM
OCMDGTO's Avatar
starter shims?
Chris D
The Following User Says Thank You to OCMDGTO For This Useful Post:
Old 01-03-2025, 06:18 PM
tom s tom s is offline
IMI,have had them for a LOT of years.Made in So Cal.Tom
Old 01-03-2025, 07:46 PM
starter shims?
yeah, the shims are supposed to give you the needed clearance between the ring gear teeth and the starter pinion. I used both of the supplied shims and its not enough to gain the clearance needed. I'm also going to check the flexplate to be sure it is within spec. This is a new build so the flexplate is new. Unfortunately, it's already installed in the car and bolted up to the trans so removing the flexplate will not be fun.
Old 01-03-2025, 10:53 PM
Sirrotica's Avatar
I've seen as many as 6 starter shims in a Pontiac with an automatic so don't quit with only 2. It's rare to use more than 2, but it's not unheard of to use more. For some reason the stick cars many times use zero shims, automatics can be all over the place.
I'm not sure if you're aware that there are 2 thicknesses of shims, 1/64th and 3/64 I've seen starters shimmed nearly 1/4".
Some buicks used a half shim on the innermost bolt to cant the inside of the starter at a slight angle away from the crankshaft centerline, this shim was glued to the starter before the starter was hoisted up to the block.
Also not out of the question that the nose was made incorrectly due to poor Q/C.
I'd stack a few more shims before pulling the flexplate.......
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 3 Users Say Thank You to Sirrotica For This Useful Post:
