Old 01-03-2025, 02:03 PM
Tom Pugh Tom Pugh is offline
Originally Posted by OCMDGTO View Post
I've had great luck with the Powermaster 9510 on multiple engines. If you're talking about front to back clearance there is a ring you can use to get more distance between flywheel and pinion. I can take a pic later if you want.
the front to back clearance is good. I used the spacing ring you mentioned to get that set. My problem is the ring gear teeth is bottoming out between the pinion teeth. I don't know how to get clearance between them.
Old 01-03-2025, 05:55 PM
BLUE TA's Avatar
BLUE TA BLUE TA is offline
hi, summit for 8 years. set the pinion clearance and good to go
Old 01-03-2025, 06:04 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
starter shims?
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following User Says Thank You to OCMDGTO For This Useful Post:
Old 01-03-2025, 07:46 PM
starter shims?
yeah, the shims are supposed to give you the needed clearance between the ring gear teeth and the starter pinion. I used both of the supplied shims and its not enough to gain the clearance needed. I'm also going to check the flexplate to be sure it is within spec. This is a new build so the flexplate is new. Unfortunately, it's already installed in the car and bolted up to the trans so removing the flexplate will not be fun.
Old 01-03-2025, 10:53 PM
Sirrotica's Avatar
I've seen as many as 6 starter shims in a Pontiac with an automatic so don't quit with only 2. It's rare to use more than 2, but it's not unheard of to use more. For some reason the stick cars many times use zero shims, automatics can be all over the place.
I'm not sure if you're aware that there are 2 thicknesses of shims, 1/64th and 3/64 I've seen starters shimmed nearly 1/4".
Some buicks used a half shim on the innermost bolt to cant the inside of the starter at a slight angle away from the crankshaft centerline, this shim was glued to the starter before the starter was hoisted up to the block.
Also not out of the question that the nose was made incorrectly due to poor Q/C.
I'd stack a few more shims before pulling the flexplate.......
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 3 Users Say Thank You to Sirrotica For This Useful Post:
