Old 01-07-2025, 09:45 PM
TheCeleryStalker TheCeleryStalker is offline
I just spoke with Gary Harrison and I will speak with the wife and probably have him rebuild it. At least have him pull the motor and diagnose what's going on in the bottom end and go from there.
Here are a couple more pics. It's kind of a unique car. I should add that since these pics were taken i've had the heads rebuilt, a Sniper 2 with Hyperspark Distro and the in tank Fuel Pump put on, as well as a higher capacity alternator. I also put in the correct 400/AC car filler panels.
As you can see, someone put a ton of time and effort into this car, so its hard for me to understand why they cut corners on the motor. The rocker arm studs were literally able to be loosened by hand!
Old 01-08-2025, 03:55 PM
rohrt rohrt is offline
Looks like a 70s motor from the brackets and PS pump setup. Is this a drum brake car? Looks like a drum brake MC. It's interesting to see AC on a convertible too.
Engine looks nice. There are other things that could cause a knocking sound.
Old 01-08-2025, 04:17 PM
Originally a drum brake car. It has Aerospace Components disk brakes on the front and the stock drums on the rear, at this point. The AC is vintage air and works great, but the heat has never worked. I know there is a valve that if installed backwards, can cause the issue, so could be an easy fix.
Old 01-18-2025, 03:19 AM
Squidward's Avatar
If you had considered a Vortech 350, why not consider a Pontiac 350? It looks identical to your 400, and could perform admirably with little effort.
In your state...
https://www.facebook.com/marketplace...9930465652962/
In my experience, the 350's haven't been flogged as hard as the 400/455 motors, especially if you find one in 2bbl trim where it was pulled in favor of bigger cubes and left in the corner of the garage for 20+ years. Just a thought.
Old 02-17-2025, 10:28 AM
The car is now in Gary H's good hands. I decided to keep it Pontiac and and go the stroker motor route. I think I just needed to find the right person, with the right Pontiac knowledge. I'm confident that Gary is that person.
The Following User Says Thank You to TheCeleryStalker For This Useful Post:
Old 02-17-2025, 11:14 AM
JLMounce JLMounce is offline
Happy to hear this beautiful bird is staying Pontiac powered!
-Jason
1969 Pontiac Firebird
Old 10-01-2025, 11:42 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
I know that this is an old thread, you mention Hanksters, my experience is beware of Coyote Classics too.
My GTO came with a wiped out cam and lifters, cracked exhaust manifold etc.
color me gone
