Old 12-24-2024, 01:00 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Default early Formula steering wheel hub/ collar repair
Over the weekend I took on the challenge of repairing 2- early Formula wheel hubs that belong to @65madgoat. These are the ones with the straight cut groove inside and corresponding part numbers.
The first one had what I was told a broken bolt inside. No. It was a broken tap that was crooked and really boogered up the screw hole. As you can imagine, a tap is hardened metal whereas the hub itself is a cast aluminum alloy. Neither my drill bits or end mill bits had a chance. Fortunately I had some dremel/ roto zip grinding bits which did the trick. I was able to grind enough of it away (I used my mill for precise grinding) to break it into smaller parts to extract out. Near the end I broke the bit, but it's replaceable.
From this I cleaned the surface up for easier working.
ID:	645146   Click image for larger version
ID:	645147   Click image for larger version
ID:	645148   Click image for larger version
ID:	645149   Click image for larger version
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
The Following 2 Users Say Thank You to Tuske427 For This Useful Post:
Old 12-24-2024, 01:07 PM
Tuske427's Avatar
Next I bored the hole out straight to be sure it was free of any tap remains as well as having a good fresh surface to bond with my aluminum brazing material. I then proceeded to heat up the hub with my propane torch to get it to the specified 725-800 degree temp needed to melt the brazing rod and filled up the hole.
After it cooled I resurfaced it on a lathe, drilled & tapped a new 10-24 screw hole and now this one is ready to be repainted and reused again
ID:	645156   Click image for larger version
ID:	645157   Click image for larger version
ID:	645158   Click image for larger version
ID:	645159   Click image for larger version
Instagram @tuske427
The Following User Says Thank You to Tuske427 For This Useful Post:
Old 12-24-2024, 01:12 PM
Tuske427's Avatar
For the second one- this one had been dropped at one point in its life and a chunk broke off. To fix this one I needed to make a basic mold of the exterior surface to contain the molten aluminum brazing rod. I did this by shaping some 20 gauge sheet metal and used a hose clamp to hold it on while filling the area up.
Note: my first pass at this the mold was too close and the material didn't fully flow through far enough to the exterior so I did it again by adjusting the mold to sit away from the part slightly to let the molten brazing rod flow further out.
ID:	645161   Click image for larger version
ID:	645162   Click image for larger version
ID:	645163   Click image for larger version
ID:	645164   Click image for larger version
Instagram @tuske427
Old 12-24-2024, 01:14 PM
Tuske427's Avatar
Here are pics of what it looked like with molten material inside, the results of my first attempt, and then the second attempt. You'll see there is some material shortage with that first attempt requiring another pass at it.
ID:	645166   Click image for larger version
ID:	645167   Click image for larger version
Instagram @tuske427
Old 12-24-2024, 01:17 PM
Tuske427's Avatar
After the second attempt I ground down some of the bulk on the exterior and then put it back on my lathe to resurface it. The final results are pretty good, though there are two very tiny gaps at each end. These should be small enough to either spot putty/ epoxy or perhaps just paint and use it. It's certainly better than it was before and is usable once again.
John- you're on your own for painting the proper wrinkle finish on these, ha ha
ID:	645169   Click image for larger version
ID:	645170   Click image for larger version
ID:	645171   Click image for larger version
ID:	645172   Click image for larger version
Instagram @tuske427
Old 01-06-2025, 09:55 PM
VCho455's Avatar
VCho455 VCho455 is offline
Nice work!
The Following 2 Users Say Thank You to VCho455 For This Useful Post:
Old 01-06-2025, 10:17 PM
4dblnkldude's Avatar
Damn! Pretty crafty, I probably would have thrown them away.
Old 01-15-2025, 05:52 PM
Formulabruce's Avatar
Nice work Tuske! I have a 69 that needs a broken drill bit removed, etc.
How far did you turn the outside down? I didn't measure them when I had them here.
Up for another challenge? .. Bruce
" Long may we DRIVE !"
Old 01-15-2025, 07:39 PM
rwfisher's Avatar
rwfisher rwfisher is offline
Well done!
The Following User Says Thank You to rwfisher For This Useful Post:
Old 01-15-2025, 10:05 PM
Tuske427's Avatar
I only turned the outside just enough to clean up the area I repaired. there's a slight curved surface to the hub and I didn't want to ruin that. It's still thicker than the later ones, ha ha. Attached is a pic- the one on the left is the one I repaired/ you painted and the one on the right is another hub from a 1977 model.
I'll DM you on the one for repair
Instagram @tuske427
Old 01-15-2025, 11:11 PM
Wow, cool pic, shows the difference well.
