Scarebird,
Yes many ways to skin this cat. I was just using simple store bought components. This keeps the labor and costs down for me. It just has to keep the bone in place. In my opinion it’s 1000% better than bending around on a ford spider to make it fit, modifying the valley pan, and crossing your fingers it all stays in place under the cover when you put it on. Stan |
Jay S,
In my application, the oil galley would be 100% blocked off with the Howard’s/Gaterman lifters while on the base circle. Thanks, Stuart “Stan” Landreth |
That was my miss understanding, you do not want the feed completely blocked .
I had an issue with an engine that had oil pressure problem once that was intermittent with this style of drop on lifter. It thought for sure it was an electrical glitch. The oil pressure would drop to zero, the engine never would make any extra valve terrain or engine noise. When I would shut it off and start it up the issue would stop, oil pressure would go to normal. I rode in it, drove it, and was just baffled. Sometime it would go 10 miles with zero oil pressure. Turned out the oil filter collapsed, it would register zero oil pressure when it acted up... Apparently this style lifter does not need much oil pressure to work. You sure couldn’t do that with most retrofit set ups, it would immediately be clattering. Last edited by Jay S; 02-17-2025 at 06:44 PM. |
I have a sneaking suspicion the Howard’s and Gaterman’s are one and the same.
Oh, and I forgot to say great work Stan!! The Pontiac hobby is glad to have you. Last edited by P@blo; 03-30-2025 at 04:59 PM. Reason: Thank Stan |
| The Following User Says Thank You to P@blo For This Useful Post: | ||
