All the rubber lines are new and the fuel pump rebuilt with an American made kit from a reputable recommend company. I’m starting to think the carb plugs are leaking even if sealed with marine epoxy.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Maybe the epoxy cracked, it happens. I know JB Weld doesn't do well with heat cycles and gas, not sure what was used. .
