Again .. You can lead a horse to water... Goes on like paint dries doesnt fall off with a little oil splash ... i even coated my pistons, bottom of the cylinders under ring travel fogged where rings ride coated all cam lobes, main,rod,cam bearings, hit lifter bores with 842
I was actuall very suprized with no smoke at all at first run no detectable blowby with PCV plugged
Used 842 in another 2 engines nothing negative to report they are still together
2 to 3 engines one can
