Old 12-09-2024, 10:58 AM
mgarblik mgarblik is offline
That all makes sense. When the engine is finally ready to fire and make noise, there are plenty of people on here that would love to see and hear a video of that little beast running. Best of luck with it.
The Following 5 Users Say Thank You to mgarblik For This Useful Post:
Old 12-10-2024, 09:47 AM
Them U-joints will be fine, for the duration. If not then go back into it after awhile and upgrade em;
Particularly fine if them needles are replaced with brass or hard steel sleeves.
They wont flat-spot, Oil film or not. Load Reference: Rear Diff spider pins to spiders and case.
Old 12-10-2024, 09:07 PM
dataway's Avatar
dataway dataway is offline
I was thinking about those universals ... correct me if I'm wrong, but doesn't the typical U-joint, after the torque multiplication of the gearbox handle a lot more torque than the crankshaft as a whole?
I know the shock loading would be way different, but sure seems like a U-joint would handle the torque. Not something I would have ever even considered, out of the box for sure.
Old 12-11-2024, 12:06 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
"Shock" certainly seems like the greatest concern here. Maybe the magnitude of a "shock" is no greater than a driveline sees, but the number of shock events will be thousands (millions?) of times worse.
The Following 2 Users Say Thank You to Jack Gifford For This Useful Post:
Old 12-11-2024, 02:29 PM
Mr Anonymous's Avatar
i've been to four county fairs and a decent number of *ss-kickin's - and I have never even thought of something like this. WELL DONE!!!!
Clutch Guys Matter
53 Studebaker, 400 pontiac
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
The Following 2 Users Say Thank You to Mr Anonymous For This Useful Post:
Old 01-17-2025, 02:29 PM
misterp266's Avatar
These guys copied your idea Jack! Don’t think it’ll see 10,000RPM though . . . .😜
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post:
Old 01-18-2025, 12:55 AM
My press would have a problem working with those u-joints!
Total Seal just (finally!) shipped my rings, so I can gap them and begin assembling the hemi-twin.
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 01-18-2025, 08:44 AM
The nuts on those flanged tip the scales at over 55 lbs!
Old 01-25-2025, 01:52 AM
Rings gapped (Total Seal, Gapless 2nd), pistons & rods installed. Torque to rotate is under 20 INCH pounds! [Lots of Torco assembly lube, and cylinder walls micro-honed to near-mirror finish; Smoky Yunick would approve!]
Head (with copper gasket and O-rings) and DOHC base plate installed and torqued.
Now upside down on stand, installing piston squirters and crank scrapers and windage screen.
Old 01-25-2025, 06:28 AM
Can you share some photos?
Old 01-25-2025, 09:58 AM
X2 on the photos! I have a folder with about 25 pics of your 4-cyl version and some pics of the car too. The folder is titled, "Jack Gifford wild DOHC Pontiac"
Old 01-29-2025, 01:38 AM
The twin is coming together. Dial-indicating the two pistons shows them to be together at TDC within half a degree!
The blower manifold can't be in place when installing engine in the car. Which means that I need to decide whether to test run it before installation. I know I should, but the support systems (oil, fuel, coolant, gauges, etc.) are such a hassle.
ID:	646846   Click image for larger version
ID:	646847   Click image for larger version
The Following 5 Users Say Thank You to Jack Gifford For This Useful Post:
Old 01-29-2025, 05:49 AM
Beautiful work that's to be proud of Jack!
Old 01-31-2025, 12:27 AM
Jack, simple AWSOME!
Dr. Thomas Sowell
Old 02-02-2025, 01:57 AM
It didn't take me long to decide to test-run it before installing it. I fixed a couple of coolant leaks yesterday, and then realized those fixes would have been almost impossible in the car!
Old 02-02-2025, 07:37 AM
Good thing you did that.
Time well spent!
Old 02-02-2025, 10:15 AM
Were those leaks fixed during a run-in? Or just during inspection and fill? If it ran, how did it do?
  #38
Old 02-03-2025, 02:03 AM
The coolant leaks showed up by just applying small pressure to the block/head coolant passages.
Still some work to go to test run it- starting with reorganizing the clutter in the shop.
  #39
Old 02-03-2025, 10:07 AM
That makes sense. Also way much mess if there is a leak. Look forward to more updates.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
  #40
Old 02-19-2025, 01:40 AM
Getting closer to test-firing the hemi twin. What a rat's nest of plumbing and wiring to support it!
Only missing the blower belts which should arrive in a few days. However, I might wait until this bitter cold weather quits, since I'll need the overhead door open.
ID:	647702   Click image for larger version
