But, if you're going to go over the entire circuit, you can try using riv-nuts at those two points first, and just replace the cables. That would save the money of the ground cable run from front to back. .
Here is a pic of my batt-frame-block ground point. It has a riv-nut in the frame.
My batt is in the front, but the principle for the circuit for a batt in trunk is the same. .
I have a high amp ALT, so at the block junction I run a ground to the case of the ALT as well.
