Old 02-04-2025, 10:23 AM
78w72 78w72 is offline
I plan to let it warm up, then shut it off and measure the carb temperature as it cools. I'll try to monitor the fuel loss inside the carb, but not yet sure how to do this.... any ideas (I won't open it up for this)? Maybe a dip stick down the vent?
Mike
Should be able to use the acc pump and watch for fuel squirting out while you operate it by hand, might not be perfect but will show when the fuel level in the bowl is so low the pump cant pick any up which will be basically when the bowl is dry or very close to it.
5 seconds of cranking isnt all that much but could be longer than some like... if thats the case just break it up some, do 2 or 3 2-3 second cranks, thats what I do when mine goes dry after about 4-5 days of sitting in hot 80-90 degree summer temps, takes longer to go dry in cooler temps. Thats for my 2 cars with 1978 q-jets... my 81 with a CCC q-jet can sit for over a week if not 2-3 & it will start up in about 3-4 seconds of cranking, not sure why but the 81 is noticeable different.
Im considering a full intank pump set up like tanks inc, but until then & for the last ~10 years Ive just dealt with it by doing a couple 2-3 second cranks when needed, not really a big deal.
Old 02-04-2025, 12:26 PM
Shiny Shiny is online now
Thanks for this. Yes, I can do this. It will reduce some volume in the bowl, but probably the simplest way to know if the pump has re-filled the carb.
Agree 2 or 3 seconds is not a big deal. I had it stuck in my head that continuous cranking is hard on the starter so have also used "bursts". My choke and fast idle are close to working so I will press to set and crank 3 seconds. Then repeat. I figure the starting sequence is designed to squirt some raw gas into the manifold so pressing before each crank makes sense to me.
I just replaced my tank and thought about it, but not worth the money and effort to me either. My car still isn't on the road so it sits a long time between starts. If I drove it every few days, the carb might never dry out. Hope to find out!
Mike
