You guys can go on thinking 4-5 seconds is excessive cranking after a car has sat for weeks and put your pusher pumps on if you wish, I'm not here to tell you otherwise, but there is nothing abnormal about that. These cars were the same way when new. EFI has spoiled the masses. In fact some EFI tunes actually crank for several seconds before they hit just in case you weren't aware. That's the starters job and they are cheap and easy to replace. If you're burning starters up you got other problems. |
Some new and aftermarket EFI ECUs require 3 rotations to reference TDC/trigger, that's why they crank a few.
Carb cars when properly setup can start on a 1/4-1/2 a rotation. The 461 I had in the LeMans with a holley, 2 pedal pumps and touch the key when cold, hot required no pumps. If it went 2 or 3 rotations I would stop cranking and try again. That's not after sitting for a while though, but it would work the same if it only sat for a day or two. .
2, gas does evaporate, into thin air, and can happen faster than a big jar full sitting at room temp, it doesnt require "excessive heat", 160-190° of normal engine temps with a thimble full of fuel can & will evaporate in a relatively short period of time, maybe not a couple hours but 24-48-72 hours would likely be different... add to that possible drain back and this type of hard starting is definitely an issue for many people, Ive read quite a few threads on it over the years. I am not a "you guys", Ive been dealing with occasional fuel evap or whatever it is in 2 of my q jet cars for a long time, both carbs were built by Cliff so I doubt there is any leaky well plugs. Also for whatever reason my other car with an 81 CCC Q-jet does not do this at all, it can sit in the same garage & same temps for 2-3+ weeks & start after just one short 3-4 sec crank... but the other 2 cars for whatever reason require 2-3 short cranks to get fuel into the carb after sitting for about 4-5 days, not really an issue to do that IMO. I can say in my experience that these cars did not do that when new or nowhere near as bad, some say the fuel was a lot better back then too so it shouldnt have been as much of a problem. Just like my 81 CCC Q-jet, Ive owned or known of other q-jet cars back in the 80s-90s that didnt do this, they would usually start in ~5 seconds of cranking the starter after sitting for a couple weeks. Just adding my experiences owning a few Q-jet cars for 25+ years, and that an experiment test closer to the real world situation of a hot carb would have better shown what happens with a small amount of fuel... just like most other things on here, everyone has different experiences. Heres just 1 link about fuel evap that supports it does evaporate and heat effects it. https://ranwhenparked.net/does-gasoline-evaporate/ |
It wasn't meant to show what happens in a car. It was just simply showing fuel won't disappear quickly without some help. Like the claim it just goes dry in a half hour or 2 days is just BS, people don't want to admit they have another issue and conveniently blame fuel quality.
If I can make these cars work fine without pusher pumps so can everyone else. But if you guys want to spend more money and monkey things up with a bunch of add ons be my guest. |
