Old 02-10-2025, 12:08 AM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Removing Weight from Doors - '72 GTO
Hey Everybody,
Are their factory door bars for safety on a '72 GTO that can be removed for weight?
How hard are they to remove and keep the glass and the ability to roll up the windows?
Thanks, Craig
Old 02-10-2025, 09:06 AM
68 GTO's did not have em. Can only improve window function.
Popular to remove on 70's T/As to improve handling. Never did it but may be hard to remove em.
Old 02-10-2025, 09:25 AM
PAUL K's Avatar
PAUL K PAUL K is offline
They're a PIA to remove on a second gen F-body. They weigh considerably less than the rumors claim.I removed one and after weighing it i didn't bother removing the other side.
Some guys will also gut the inside supports that hold the window roller channels and attached parts. That may help with the removal of the crash bar. But you still have to be careful not to damage the exterior paint and sheet metal as you cut out the bar.
For me an extra twenty minutes on the treadmill would've been a better strategy but I shortly gave up on that and concentrated on more power.
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 02-10-2025, 09:45 PM
CraigG.'s Avatar
Thanks guys this makes a lot of sense and yeah more exercise and less beer
Old 02-10-2025, 10:30 PM
mrennie's Avatar
mrennie mrennie is offline
I have 71 doors on my car which should be the same, and they do indeed have a crash bar the full length about 1/2 way up. I can't imagine how you could cut them out without either damaging the door skin or slicing your arms open trying to work through the small access holes.
There is no relationship between the crash bar and the window regulator; I can't see any issues with the glass fitting or operating without that bar.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
The Following User Says Thank You to mrennie For This Useful Post:
Old 02-11-2025, 04:54 AM
gman005's Avatar
gman005 gman005 is offline
I have a set of fiberglass doors for sale,
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport. RIP
75 Grandville Convertible.
Old 02-11-2025, 06:37 AM
That crash bar started with the 1970 A body models.
You would have to use a torch to cut most of it out or use the Swiss cheese method to drop some of the weight.
Old 02-11-2025, 10:14 AM
PAUL K's Avatar
Or a cut off wheel
Go fast, see Elvis!
Old 02-11-2025, 12:40 PM
Old Goat Racer's Avatar
An old friend of mine used a sawzall to cut his out.
Everybody knows somthin.
Nobody knows everything !
Old 02-11-2025, 01:16 PM
sdbob sdbob is offline
I removed both sides on my 70 F. Drilled the spot welds on jambs. Then put a heavy steel plate between brace and door skin then cut plate with torch.
Old 02-11-2025, 03:19 PM
Keith Seymore's Avatar
I did the ones in my Chevelle back in high school (probably the summer of '78).
Used a die grinder with a cut off wheel.
Car was 4100 lbs when I started; it's down to 3550 (without me in it) after almost 50 years of trimming.
K
'63 LeMans Convertible
'63 Grand Prix
Old 02-11-2025, 04:33 PM
72projectbird's Avatar
I've always thought that if you're chasing weight loss to the point of removing steel from the doors, you're better off going with glass or carbon doors instead.
Even more so nowadays, where getting the windows to function like original isn't as difficult as it used to be.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 02-11-2025, 05:33 PM
Not allowed for me.
Only glass allowed is hood and bumper.
K
'63 Grand Prix
Old 02-12-2025, 02:04 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
But removing the beams is free, and fairly easy
Old 02-16-2025, 03:38 PM
BDHABT's Avatar
BDHABT BDHABT is offline
We removed the crash bars in pieces on our '70 Firebird,it was worth it.
The pieces weighed 15lbs per side on my buddies scale that he used for shipping.
It was a pain,and the very end of the bars are still in there,but 30lbs is 30lbs.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
