Ok, in the rest position, it doesn't need to go all the way to the end of the travel slot. And yes, it does appear to be 'different' than the original.
The 'adjustment' happens internally with the contact plate and 'washboard'. It's not relevant to the rest position of where the actuating post is. So the new one you have, and this is from memory, to reset it, you slide it to the end of travel towards the firewall, and quickly release it so it pops back to the rested position. Hopefully someone else can confirm that, but I somehow recall that being the procedure. Then you do the WOT set. .
I respectfully disagree. I just did a search for th400 kickdown switches and there are many out there that look identical to what I just purchased but I have found several that claim to be new old stock that have the small tab on the slider. I believe the ones being sold new are not the same part number and do not function like the OE equipment was intended.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers.... |
Spring back to 'center' is the at-rest position when installed, correct? It doesn't prevent the pedal to return fully does it? .
Ok, I get it now, the F-body ones work in opposite direction of A-body, like attached pic.
The at-rest position is in the center of the switch travel slot. As you push the peddle, it moves away from the firewall. Take a pic of it installed. If you are saying that it doesn't contact the switch until it's almost at WOT, either the bracket is bent, or the switch is installed backwards maybe? Take a look at the pic. That is at-rest, and the switch actuator post is in the center of the switch. .
I'd check the switch for continuity when pressed and released, like when throttle at idle and when floored.
The switch is just an on/off setup. 12 volts when pushed to floor which goes to solenoid inside tranny. In combination with the vacuum modulator and governor the tranny shifts. GM didn't want the switch to work except when at full throttle basically. Relying on the vacuum and governor to handle shifts.
