Has anyone set up this cam up with 106 intk centerline vs 108?Thanks in advance
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Was that an intentional pun? :-)
well going the other direction would be retarded.
Old Faithful ICL
https://forums.maxperformanceinc.com...d.php?t=735243 "Dave told me 106 - 108 with a new timing set" .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
| The Following User Says Thank You to Steve C. For This Useful Post: | ||
Ok ... It will run fine @ 106.....and will "retard" to 107 or 108 as timing chain relaxes
Thanks for the link steve,I'm running a 273 gear and hope this will work better with timing at 106.I still would like to perform a compression check.Prior install it had 180 I'm expecting 190 -195 ,if it goes higher then 200 I'll be going back to 108.
My original OF1 is degreed in at 108, with 3.90 rear, 28” tire. Not operational just yet…
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb Last edited by grivera; 02-27-2025 at 07:47 PM. |
Well this is strange, I performed a compression test and only got 160 psi,seems low.Was expecting 180 at least.Did test with engine on stand .May need to seat rings and then retest.
Stan
Engine hot for the test?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
OK finally running again,feels a little more responsive off idle.Haven't made any full throttle stabs yet still breaking in,is a little noisy until lifters fill up.Will do a compression test soon,but curious if I will get legit readings due to the lifters compressing and closing the intake sooner
