Old 03-09-2025, 02:08 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
My 428 with Ross flat tops and zero-decked block and 72cc E-heads is 11.4:1 and is happy with 91 octane. Cam is 248/254 @.050 and 114 LSA.
So much of this is dependent on cam timing. It's the dynamic CR that's important, not static. Dynamic CR is determined from when the intake closes on the compression stroke. The later the intake closes, the less dyn CR you'll have.
An example: this engine with the same cam originally had 87cc E-heads (9.7:1-ish) and I accidentally figured out that it ran better on 87 octane than 91. With the 72cc heads, throttle response is sharper, and I picked up around 1/2 sec in 1/4 mile. Much happier motor!
The Following 2 Users Say Thank You to hgerhardt For This Useful Post:
Old 03-09-2025, 09:45 AM
torqjunki's Avatar
torqjunki torqjunki is offline
Default Great info.
Can you post up details on the 248/254 cam your running please sir? Working on similar combo.
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
Old 03-09-2025, 02:53 PM
hgerhardt's Avatar
Here you go. As you can see, it's ground 5 deg advanced, so I installed it straight up.
Also, all of my experience with this engine is with the older E-heads. Both my 87cc and 72cc heads are 27+ years old. In fact, other than replacing the valve springs a few years ago, It hasn't been apart in 25 years.
Name:	cam card GTO.jpg
The Following User Says Thank You to hgerhardt For This Useful Post:
Old 03-10-2025, 08:37 PM
torqjunki's Avatar
Thanks!! I like it. I don’t see LSA
Old 03-10-2025, 11:15 PM
hgerhardt's Avatar
It's there on the cam card, you just have to do some math to see it. (109+119)/2 = 114.
What I like about this cam is how well the engine likes to rev. 4" stroke (434 cu in.). Enough torque to get wheelspin (with 255-section tires) by hitting the gas at 55 mph in 2nd gear (which is pretty ridiculous on the street!). So it makes good torque plus has that nice, high-RPM lunge (shift at 6500).
And even though these 72cc heads have the old combustion chamber, max power happens at 31 deg total timing. With the old 87cc heads, I needed 37 deg. So good quench combined with high compression seems to work here. (11.4:1 on the 72cc and 9.7:1 on the 87cc)
Note that I did not just swap heads when going from 87 to 72. I also decked the block to make it parallel to the crank but also got the pistons slightly above the deck (forgot exactly how much). So I increased compression plus quench at the same time.
