Old 03-16-2025, 11:05 PM
Default Saggy arse...
I have come across some used leafs from an 80 TA for cheap and my girl is losing her inevitable battle with gravity.
Would they fit my 74 TA or not worth my while and should I replace with new?
Thanks!
Old 03-17-2025, 04:01 AM
new.
Old 03-17-2025, 10:10 AM
78w72 78w72 is offline
Yes they will fit, if they are in good shape and not sagging they would be a budget option to fix yours.
But new would be best, avoid the universal 5 leaf or cheap no name and go with a well known company... PTFB has very nice rear leafs with a mils 1-1.5" drop from factory.
Old 03-17-2025, 11:27 AM
Outside of my budget this year, especially with the exchange/tarrif bs.
Maybe I'll try these out just to she how she hangs to buy some time.
Thanks!
Old 03-17-2025, 11:52 AM
Thanks!
Would be good if they are still installed on the car to see how the rear sits. If they arent sagging & priced cheap it would be a low priced fix or band aid until you can afford new.
But unless you plan to do some racing or want to improve the suspension over stock, original springs in good shape will last a long time.
Old 03-17-2025, 04:10 PM
His car sat way better than mines...he did a lowering spring kit recently
Yes, that is my ultimate plan - suspension upgrade
Baby steps.
Old 03-18-2026, 10:57 AM
I found a "new" set that have been sitting for a long time for cheap.
Would they need to be re-arched? If so, any idea ballpark cost for that and would they need to be on the car?
Old 03-18-2026, 06:04 PM
694.1 694.1 is offline
Always been quite surprised how poorly the First Gen springs held up Very common for them be be broken & sagging at the 10 year mark.
Crappy steel? Crappy vendor? My F 150 springs are 25 years old and super. No excuse...
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 03-18-2026, 11:20 PM
They were somewhat squatted compared to the Camaro. Maybe they launched better lol
Old 03-27-2026, 10:56 AM
TimsTA's Avatar
TimsTA TimsTA is offline
Re-Arch…
74 Super Duty Trans Am
Old 03-27-2026, 05:57 PM
Re arching is not worth the R&R. They were crap to start with & would remain so after arching. Ask me how I know
7th Firebird
57 Starchief
Old 03-27-2026, 06:30 PM
Skidmark's Avatar
Skidmark Skidmark is offline
Thanks!
That is exactly what i would do.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
Old 03-27-2026, 10:53 PM
I bit the bullet on these barely used aftermarket ones for my honeycomb upgrade.
I guess ill put them on and see how she sits and then golden arches if necessary.
Old 03-29-2026, 05:53 PM
Steve Barcak's Avatar
My 78 had a droopy butt too. I went the simpler way and installed helpers/boosters about 4 years ago. they install super easy. There is no disassembly involved and are hardly visible. One day when I restore the car, will likely change springs but, while it is a driver ( and have driven all over the USA), these simple helpers work great. No noticeable difference in ride quality as well. If you would like a better pic of them if you are not familiar, let me know. am very happy with the way the car sits, handles, etc. cheap and easy fix. this pic from Friday. Even looking up at the car a bit, you cannot see them.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 03-30-2026, 10:52 AM
Like shackles you mean?
Old 03-31-2026, 10:02 AM
The helper/leveler springs are not shackles, they are short pieces of leafs that attach to the existing leafs & add support. They are more popular for trucks/suvs to help carry heavier loads but will work to help raise/level car leafs too.
A friend of mine used them on a later 90's S10 blazer when he was moving out of state and had it fully loaded with heavy tool boxes & other stuff then trailered his race car behind it, it was drooping bad even with the helper springs but without them no way he would have made it.
https://www.jegs.com/i/Hellwig/207/5...qKLbI2OLg8Ku6M
Old 03-31-2026, 01:15 PM
Ohhhh...I think I have seen those before but didn't realize it was an option
Thanks for the clarification
Old 04-01-2026, 09:51 AM
They make universal ones or possible car/year specific for these older cars. Nice oprion to have but personally I would prefer good used springs like the ones you mentioned or just buy new & put the cost of helper springs towards new OEM or PTFB type.
Old 04-01-2026, 12:00 PM
The ones I just found have very few miles on them and aftermarket - not sure brand.
They were fire red so I just painted them.
Got the new tires so now I just need to finish the honeycomb restoration.
Things are coming together!
Old 04-01-2026, 02:20 PM
PAUL K's Avatar
PAUL K PAUL K is offline
JC Whitney and others used to sell a small coil spring that would clamp to the axle tube and push up against the frame. Lots of shocks made with a coiled spring that helped raise the rear body.... Over the years it's changed significantly as to what was the "cool" stance. Air shocks are another option.... The first time changing the rear springs can be a bit of a challenge. Once the rusted bolts and stuck bushings are taken out of the equation it's a pretty quick job.
Go fast, see Elvis!
