Old 03-17-2025, 07:39 PM
BILL BOWMAN1's Avatar
Default 1990 Chevy truck rear help
I have a 1990 Chevy pick up truck. It’s one of those goofy light duty 2500 series. Has a 14 bolt 9.5 ring gear. Going to replace the axle seals, but I want to have the parts before I tear it apart. Does that have a taper race and bearing, or a sealed type straight cut bearing?
Looking on line is not helping much.
Old 03-18-2025, 07:01 PM
unruhjonny's Avatar
have you tried asking for help on a site like gmt400.com ?
There tends to be a lot of activity there, and someone there should be able to tell you what you need.
I have bought parts for my 1992 K1500 from both Rockauto and LMC - As I am guessing you are aware, both sources will sell you wrong stuff, so you have to do your own due dilligence...
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 03-18-2025, 09:23 PM
Thanks.I did some more searching and think I got it figured out.
Old 03-19-2025, 04:16 PM
Sirrotica's Avatar
Bill, here's a link to a video for a complete rebuild on a 9.5 single rear wheel, semi floater, 14 bolt GM axle.
https://www.youtube.com/watch?v=RthfIzzBckM&t=33s
The axle bearings and seals are similar in construction to a 10 bolt car axle. Standard roller bearings that the axle shaft rides on, and an outboard seal that reside in the end of the axle tubes. Axles are retained by horseshoe locks that require the spider gear shaft be removed.
I hope this may be helpful........
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 2 Users Say Thank You to Sirrotica For This Useful Post:
Old 03-19-2025, 09:07 PM
Thanks, I will check it out for sure!
Old 03-19-2025, 11:05 PM
wheels wheels is offline
Default Square bodies
Another place to get your question answered is CK5.com. They are a family oriented site that can answer any question on square bodies.
https://ck5.com/forums/
Old 03-20-2025, 12:09 AM
unruhjonny's Avatar
/\ square bodies (as far as the trucks are concerned) are 1973-1987;
I’m not sure if the rear end for a late square body is the same as a GMT400.
LINK
1970 Formula 400
