Old 03-20-2025, 11:35 AM
The timing chain gets plenty of oil from the passage feeding the fuel pump excentric, so no need to bleed off any more oil pressure with front galley holes.
If you drill & tap the front galley for plugs make note that there's a cross feed oil oil on one side so you can't tap that hole to deep otherwise you will partly block that oil passage off before the plug gets tight enough to both seal itself and hold .
