Old 03-29-2025, 10:04 PM
DaleO's Avatar
DaleO DaleO is offline
Default Two different TH400 pans
I thought I was headed to fixing my leak by finding a pan with a raised rib around the flange perimeter but I might have a problem. My trans has the "can" style filter and I see now it's pickup has a small lower depression in the pan. My "new" pan with the rib does not. Can I use this pan with the can filter pickup?
ID:	649606   Click image for larger version
ID:	649607   Click image for larger version
Old 03-30-2025, 01:26 AM
65 Lamnas's Avatar
No. If you're gonna stick with the "can-style" filter, you MUST use the pan with the heel print. If you're handy though, you COULD upgrade to the 67-1/2-later style broiler pan type filter, and then you can use the later pan with dimples. The later style filters do a better job of filtering and are cheaper and easier to procure.
Or else buy a used heel print style pan with a rib. https://www.ebay.com/itm/11631509093...Bk9SR5SSuti8ZQ
The Following 3 Users Say Thank You to 65 Lamnas For This Useful Post:
Old 03-30-2025, 04:56 AM
Kenth's Avatar
Kenth Kenth is offline
I would use Permatex Aviaton 3 to fixate a new cork gasket on your original pan.
Flatten the screw holes if necessary before.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-31-2025, 08:16 PM
Schurkey Schurkey is offline
Yup. Convert to the newer filter, dump the "heel print" pan.
I will never use gasket sealer on a trans pan. If a "quality" dry gasket doesn't seal, something else is wrong. Common issue is a different leak entirely, drooling down onto the pan gasket--looks like a pan gasket leak but isn't.
Old 03-31-2025, 10:06 PM
DaleO's Avatar
Thanks everyone. The filter is new so I'm not going to upgrade at this point. Upon closer inspection I had over tightened the screws pinching the gasket too much in two locations which corresponded to the weep points. I've ensured the pan is flat and screw holes are ok too. I got a new fiber gasket and have Permatex Aviation #3 to the pan but not the transmission. I'll never have to change the fluid/filter again anyway so right or wrong I'll be back in business.
Old 04-01-2025, 09:04 AM
rustyrelic rustyrelic is offline
not a expert by any means, so more asking a question on the subject. I would think you could change the pickup tube and filter easily enough, but does the earlier valve body have the bolt hole that suspends the later model filter? I am thinking no?
Old 04-01-2025, 01:44 PM
65 Lamnas's Avatar
Correct, so you have to either drill and tap or else swap out VB for a later one.
Old 04-01-2025, 04:40 PM
DaleO I have one of those filters new in the box I will make you a great deal on for your next change if your interested? I might even have two.
Old 04-02-2025, 08:21 AM
Wishing the modern reinforced silicone pan gaskets (ref 4L80, 4R70w) were made for TH400s. Aftermarket would do well to make.
Old 04-02-2025, 12:13 PM
65 Lamnas's Avatar
They are. I have one.
Old 04-02-2025, 12:41 PM
grivera's Avatar
grivera grivera is offline
Please share link
Will Rivera
Old 04-03-2025, 04:36 PM
I did a quick search for the silicone pan gasket they are available everywhere Summit Amazon do a google search not to hard to find. Thanks 65 lamnas
