Old 04-18-2025, 05:23 PM
Elarson's Avatar
Elarson Elarson is offline
Default 2nd Gen Firebird Measurement
I got the 2" drop rear leaf springs from Detroit Speed. I finally got the car on the ground and it doesn't look much different than stock ride height to me. Maybe it's an optical illusion from the short tires??
Anyway, if a few of you would be so kind as to measure your 2nd Gen's from axle centerline up to fender lip, so I can compare. See attached picture. Mine measures 16"
Thanks in advance!
Eric
Old 04-18-2025, 06:29 PM
jpg69bird jpg69bird is offline
Car is still away, but this is the stock ride height as measured from the underbody, out of the 76 assembly manual.
Name:	Assembly Manual - All (dragged).jpg
69 Firebird Conv, 350 HO w/3 on the tree swapped to Tremec 5 Speed - Sold
72 GP, 400 Auto - Sold
09 G8 GXP M6 Orig Owner - Sold
76 Trans Am 455, 4 Speed - Current
The Following User Says Thank You to jpg69bird For This Useful Post:
Old 04-19-2025, 10:36 AM
PAUL K's Avatar
PAUL K PAUL K is offline
I don't normally measure from the center cap up but understand why your are. The white car is all original low mileage. The blue one seems to sit correct. The white car has a 235/60 the blue car a taller 255/60.... Hopefully these pictures are helpful.
ID:	650501   Click image for larger version
ID:	650502   Click image for larger version
ID:	650503   Click image for larger version
Go fast, see Elvis!
Old 04-19-2025, 11:31 AM
My 70-73 rear measurements from ground to wheel well lip are around 27 1/2 to 28 inch. Those measurements are from TAs with original springs.
The Following 3 Users Say Thank You to Tellyshavilli For This Useful Post:
Old 04-19-2025, 01:33 PM
76TA462 76TA462 is offline
For my second gen (1976) I used the Hotchkis Sport Suspension Lowering Leaf Springs Package - 2409C designed to lower 1.5 in. With the OEM rear leaf shackles my wheel center to fender was 14.5 inches. On dips etc. my exhaust was hitting the road a lot. In the pictures my spacing is now 15.25 inches. I raised the car 0.75 inches by fabbing up longer shackles (the difference in the shackles isn’t even obvious and still tucked under. Not like those foot long shackles of the 70-80s LOL.) Running 285 40 18.
ID:	650509   Click image for larger version
The Following User Says Thank You to 76TA462 For This Useful Post:
Old 04-19-2025, 01:37 PM
Mine seems to match Paul's measurements.
Old 04-19-2025, 01:50 PM
PAUL K's Avatar
Nice looking car!
Go fast, see Elvis!
Old 04-19-2025, 02:11 PM
45 years of ownership and changes, and still having an awesome time with it. Thanks.
Old 04-19-2025, 03:09 PM
Elarson's Avatar
Thanks for all the replies. That tells me a lot.
I need to look into those Hotchkis springs....sounds like they may be better for road courses than what I have now.
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 04-19-2025, 04:50 PM
PAUL K's Avatar
Eric have you looked a Landrum? ..... We used a lot of the springs for drag racing and they worked great. They also made us several pairs of "custom" street/strip springs. I believe their specialty was circle track.
Go fast, see Elvis!
Old 04-19-2025, 06:17 PM
srmmmm's Avatar
srmmmm srmmmm is offline
I'm running a five leaf spring assembly that was designated for the 1975 Chevy Nova police suspension option. No special additional curvature, just a stiffer rate.
Distance from axle centerline to wheel opening lip is 15.75"
Name:	#49 Outdoors.jpg
Old 04-20-2025, 08:04 AM
Elarson's Avatar
I measured my rocker panel height last night. I'm right at 8" so that double confirms all the other observations. I have "2" drop" springs and tires that are 2" shorter than stock and I'm only 1/2" lower than stock. Grrrrrr.....
Thanks....everybody was a big help.
Eric
Old 04-20-2025, 10:47 PM
JLMounce JLMounce is offline
This is for your road race second gen, correct? They are a bit spendy and I don't know your budget, but I'd talk to Global West about their Cat5 leafs.
-Jason
1969 Pontiac Firebird
Old 04-21-2025, 09:37 AM
78w72 78w72 is offline
PTFB has some nice 1.5-2" drop springs, priced better than the other big suspension companies. I have had them on my 72 firebird along with some of their other parts, been in use for 10+ years & sits very nice, lower than my stock other suspension 2nd gens using factory size tires at about 27-27.5" tall.
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
Old 04-22-2025, 10:56 AM
The Champ's Avatar
Eric
Your post got me to go measure my wife's '72 Camaro that still has the original 53 year old leaf springs in the back. 13.5"! My short (25.7") 275/40/17's fill the wheel well as shown in photo below.
I've been contemplating getting new rear springs to alleviate the rear end sag, but have been hesitant on what springs to get to lift the rear .75 - 1" in the rear.
Front springs are 2" drop Eibach coils installed back in 2001.
I talked to PTFB and he thought their GT Pro leaf kit springs would be my best bet and they come with shackles that have two positions to give me easy adjustability if I needed more lift:
I might cheap out as I need to replace the 7 year old tires this spring anyway. Currently running 275/40/17's (25.7") and go with 255/50/17's (27.2") to get the .75" that I'm looking for. Fronts are currently 235/45/17's (25.3"), but looking at 245/45 or 225/50/17's this time to gain maybe .25" up front.
Speed bumps and highly crowned rodes are a b!tch....
Name:	Camaro DSC_2067.jpg
The Following User Says Thank You to The Champ For This Useful Post:
Old 04-22-2025, 01:56 PM
srmmmm's Avatar
These are 235/55R17 with what should be, stock height springs on mine.
Name:	#48 Side Stance.jpg
Old 04-22-2025, 03:46 PM
Steve C. Steve C. is offline
When I obtained a copy of the AMA specifications for my 1970 2nd Gen they stated this as the factory ride height. These are height dimensions from the rocker panel to the ground in two places. The forward point on the rocker panel is located 36.3 inches from the front wheel centerline and it is supposed to be 6.5 inches off the ground. The rear point is 16.1 inches from the rear wheel centerline and is supposed to be 5.5 inches off the ground.
Old information here:
Old 04-22-2025, 04:21 PM
srmmmm's Avatar
Did it indicate the tire size for that? Seems a bit low, but considering that might be the spec with the base F78/14 tires, then correct.
Old 04-22-2025, 07:53 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Thanks in advance!
Eric
Have you driven it some to settle those new springs?
Old 04-22-2025, 08:16 PM
jhein's Avatar
jhein jhein is offline
There's a pretty big discrepancy between the numbers in these two posts. Below is what I found in my 1970 assembly manual. The car they show is a 1st gen but if you look in the bottom right area of the page it says it's for 1970.
