Good morning everyone!
Building a 77 Y82 4 spd car thats missing her original engine. Trying to put together the most correct replacement that I can. I am in search of a WA block dated November of 76 ideally. Also 6x4 heads and an intake part # 525355 in the same date range! |
lol, I just scrapped out a set of heads.
All I have left is a water pump off a w72, and the alum goose neck. |
ahh just my luck 😂 what is the date on the water pump sir?
I will get it out today and look, from what I remember it was off a 78;w72.
Heads are tough, no one wants to ship, they were up here for a long time. Last edited by burd; 04-09-2025 at 08:59 AM. |
sounds good brother thankyou! Yea thats true, might have to start hitting the swap meets!
I don’t know where your at, but I have a standard bore 77 WA that spun a main. The block would need to be line bored or need shim stock on that main to be saved.
I also have a balanced and fresh machined (.020”/.020” with all bearings) rotating assembly stock stroke 3.75” (for Eagle H beam rods) with 4.15” ICON flat top forged pistons. I used the connecting rods on another engine, would need another set of eagle connecting H beams. I am in SE Nebraska. |
| The Following User Says Thank You to Jay S For This Useful Post: | ||
whats the date code on the block sir? im in central Texas
E127 May 12 1977 It came out of a 4 sped TA in the KC area that was salvaged. |
any word on that water pump?
also searching for a distributor part number 1103271 and 55A alternator p# 1102478 ideally with a november of 76 build date
alternator for ta w 72 in 77 or 78 is 1102854 heavy duty and I got one. PM me if interested dated j of 1976, i know I have 1102480 and 1102486 too
awesome, what amp is the 1102854?
ahh unfortunately i need a 55 amp in order to be correct for my car. Had ac but no power windows or doors and no defrost
I believe it's correct part of w 72 package but I might have a 55 amp alternator look.up wallace racing alternator codes. it was my impression that all w 72 cars got the HD alternator .
yea its been tough finding verifiable information on what the correct alternator is for certain. Hoping to learn more on this forum.
do you have build sheet or phs docs?
PHS won't help with the alt part number. Buildsheet would only show the correct two letter code for the original alt then you would have to decode.
Here's the actual '77 model 400 T/A or Formula usage: 1102478 55 amp...... AC or heated rear glass 1102492 37 amp...... non AC 1102854 '63 amp..... AC & heated rear glass Looking myself for a Dec '76 dated "2478". Will find one, get into quite a few boneyard stocks.
| The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
Look at a buildsheet from another car like yours, I know a guy w/ a data base of them, you can buy a blank one, make one for your car the best you can. PHS isn’t much good.
Without a BS, doing a numbers match car is pointless. |
| The Following User Says Thank You to burd For This Useful Post: | ||
