| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
I’m gonna have to replace my rotten old garage doors one of these days. Is that a job that a guy that can build a hotrod handle, or am I gonna be wishing I just called a professional?
Single 8x8 size. Thanks.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
In my garage when I built it I ordered the door and installed myself. It is 8ft. high and 10 ft. wide. Easy to do yourself.
DBANDGB |
I've installed the kind with the long stretchy spring. Fairly easy if you have a good surface to bolt the tracks to.
The kind with the wind-up spring, not sure I'd try that myself.
Thanks guys, I will try to find a helper friend that has done this before.
I would get a price for a door installed and just the door. Do you have an opener on it now?
I would pay for the install. That way you get a warranty on the installation. I would also go with the torsion spring setup. They work much smoother than the cable springs. They also offer a lift that attaches to the end of the torsion spring freeing up the space between the rails to install a car lift.
My son owns a garage door company.
He has some pics of very bloody springs and floors where someone tried the DIY route. hire it out.
72 Luxury Lemans nicely optioned ![]() Best so far 12.40 Milan Dragway 2025 I am the Thread Killer! |
| The Following User Says Thank You to indymanjoe For This Useful Post: | ||
Good luck.
72 Lemans sport 462 auto 75 Trans Am 4 speed 39k miles |
My brother in law has been doing these doors for 25 years at a local company. His phone is full of those pics. Effing disgusting.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
| The Following User Says Thank You to 4dblnkldude For This Useful Post: | ||
Have it done. As stated, the torsion spring set up with wall mount openers is the way to go even though a bit pricier. Perfect time to put in rails that will bring the door closer to the ceiling also when open…
I think when the time comes, I will job it out. I don’t want to be stuck with an unusable garage if something goes wrong. And I have heard those springs come apart before, like a cannon going off, thankfully they were safety wired.
If you're handy, it's an easy job. Even with torsion springs, use 2 18" 3/8 extensions to tighten the springs.
| The Following User Says Thank You to necdb3 For This Useful Post: | ||
If you've done mechanical work you can install a garage door with a torsion spring. You just need 2 rods to fit holes in solid end of torsion spring. Just take your time turning torsion spring. The hardest job is raising door without springs attached,then attach springs. I've done few over the years just none lately.
It’s gotta be easy doing one, the tolerance is huge compared to a reg door.
Remove the red pull string though when putting a new opener on. |
If you can do the torsion rods on a Firebird trunk lid …..
73 T/A 455, 4speed |
