Old 05-23-2025, 04:17 PM
grivera's Avatar
grivera grivera is offline
Originally Posted by 65 Lamnas View Post
I don't have anything but break-in and dyno time on mine. Actually getting ready to put the engine in and decided to pull distributor. Noticed some wear on the Watermelon-ized gear which I don't like. I don't know much about that type of gear, but I think it's just a coating. Looks like the coating is gone on the drive side of the gear teeth. Maybe it's insignificant, but I've never had an issue with the BOP composite gear. Another 1/8" of engagement would be nice.
Do you have a roller cam? Assume that has massaged the cam gear enough?
BTW - mine arrived today!
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 05-24-2025, 02:12 PM
65 Lamnas's Avatar
I have a roller cam.
The whole thing about “smoothing out the cam gear” by running a bronze or steel gear came about roughly 20 years ago. Crane Cams had an issue where the final machining of the cam gear was missed and A LOT of cams were sold with an extremely rough cam gear. It was recommended to run a bronze gear for a couple hundred miles to knock off this roughness and then switch to a composite gear.
“Massaging” the cam gear hasn’t been a “thing” for a long time.
Old 05-24-2025, 07:55 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Cliff has stated in the past smoothing the edges of the cam gear with a diamond file. Just tiny swipes off the machined edge from what I recall.
costs too much
