I have a 428 HO being built for my '69 GP, I want to go with a hydraulic cam and eventually run it is a FAST or pure stock race. As far as lifters go, who should i stay away from, I'll probably end up calling bullet and Butler to see what they recommend. My goal is to put the car in the mid to low 13s with 722 heads, LB manifolds, factory aluminum intake, 3.55 gear and a small convertor. One cam I'm thinking about is the crower 60919 470 lift, 231/240 duration at .50.
| The Following User Says Thank You to se428bandit For This Useful Post: | ||
That’s what I’m running in a 467 and I love it.
Talk to someone like SD455DJ first.
Crower 60243 is a small step down from the 60919 and in my opinion a better choice for a 428 in a somewhat heavy GP with 3.55 gears.
The Summit 2802 would be another one worth considering.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
So 64speed, do you run your car in the 1/4 mile Fast or pure stock classes like the OP is looking to do?
Just wondering why you have experience in things like this, plus your giving recommendations from your motor which is 35 CID larger then his.
| The Following User Says Thank You to steve25 For This Useful Post: | ||
Was it a recommendation or just a statement? I have dabbled in the track in my youth but no I haven’t been in years. I can tell by my ass dyno my car is faster than 13 seconds but by how much I don’t know. Yes I have 35 more cubes. I also have 1.7 BBC Chevy rockers and it’s still smooth as a babies ass at idle so I’m sure 35 cubes aren’t gonna make it unpleasant. Again just making a statement.
You can talk to Tim Goolsby at Ultradyne/Bullet about exactly what your needs are. He is tough to get in contact with though. Just keep trying. Morning is best. Your biggest challenge is going to be finding a cam core to grind. I just a week ago ordered one of my favorite mild cams from them. 276/286 on a 112. That's a nice cam and makes good vacuum for power brakes and good torque for a heavy car. A custom grind I had made for my old NMCA 4500 lb. car was a 276/284 on a 113. NMCA had a minimum vacuum rule in those days and this cam just made the grade. It propelled that heavy boat to 108 MPH trap speeds with a 421 back in the 1980's. Rules required stock heads, intake and exhaust manifolds. Enough for a class record. I have had good luck with Crower cam saver lifters. The extra oil on the lifter foot certainly doesn't hurt. Good luck with your engine.
If you have some old Pontiac cams, he may be able to re-grind one to meet your needs. Finding a new core is difficult and it looks like there may not be a new run of them by CMC for 2 or 3 years if ever. |
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
Dennis |
To answer your Question: The exact cam I really loved is a custom grind. Here are the specs. Advertised is @.0045"
Adv. Intake 276 .050, 221 , .200, 132 lobe lift .3027 Adv. Exhaust 284 .050, 232, .200, 143 lobe lift .3273 ground on a 112-113 The exhaust lobe is a little aggressive but it made 7 more HP than an alternative slightly gentler exhaust lobe I will list below. We had to run the stock "093" heads which have small valves and poor stem angle. The exhaust flow is especially poor with the required exhaust manifolds. That cam really helped. The alternative exhaust lobe, which is more gentle and popular, would probably work fine with the later heads. It is: Adv. 286 .050 230, .200, 139 lobe lift .3027 These cams were easy on the valvetrain. I ran a 276/286 in a 421 HO 9 passenger Catalina wagon over 100,000 miles. Pulled a 19' Sea Ray probably 10,000-15,000 miles over many years to lakes all over OH, KY, TN. That wagon weighed 5050 Lbs. It ran 14.60's all the time with that cam. Turbo 400 and 3.42 rear. |
Edelbrock Round Ports. My engine builder worked it out and got a good pattern
If you want to take full advantage of the intake flow of those 722 heads you need to run .500” to better yet .550” lift since this is where peak flow takes place.
You also you do not want to run the stock type Tulip intake valves, the tulip valve on the exh side is fine. You want to run a D port type nail head intake valve. Also not running the stock type Tulip intake valve with its big chamber side dish will help with out with compression. Have a valve job done on the intake side that maxes out the full OD of that 2.11” valve. Only use a 2 angle valve job that keeps the stock 30 degree seat but apply a 60 degree bottom cut that takes that 30 seat width down to .050” but no more then .055”. I hope your intake manifold is one that was originally on a 400 because the latter production ones and the replacement off the shelf ones where had a shallower plenum and runners and due to that made less power. I forget exactly when this casting change took place. But I think you can find this info still on line. If you can’t let me know and I have it here somewhere and will dig it up. Exh wise these 722 heads are sluggish due to there large runner area after the short turn. Running exh manifolds will help this condition out especially if you take the time to open up the inlet of the exh manifolds such that they are 1/16” bigger then the exh flange area of the head. If the exh manifolds have the meat make the bottom 1/8” larger so you end up with a nice lip on the floor to reduce the low to mid speed reversion that the excess runner area in the heads produces. Valve job wise on the exh side max out the 45 seat OD to 1.805” then add a 30 degree top cut. This arrangement should leave you with a .030” wide top cut. On the valve itself add a 30 degree back cut that takes the .100” wide seat area down to .075”. If the Q-jet you will run was off a Firebird note that many of them had restricted secondary openings, so be sure to grind that limiting tang off.
Your D-port #62 heads are good as is the cast iron intake and give nothing up to a RAIV top end in the lower rpm range (idle to 3500 rpm). You need low end torque to move your relatively heavy GP and the 62’s will help there. With at least 10.0 to 1 compression, the 2802 cam (224/234/114 at .466”/.488”) is a great choice with Hy-Lift Johnson lifters. You’ll make the 16” Hg at 1200 rpm easily and your 3.55’s would work well a small converter. Any RAIV clone cam is not going to pass the 16" Hg. minimum and have a reasonable sounding 'stock' idle. Dennis |
| The Following User Says Thank You to SD455DJ For This Useful Post: | ||
Unfortunately it seems all the HFT lifter brands have issues right now, including HLJ. Nitriding the cam is cheap insurance against getting a set of 16 lifters that doesn’t have issues on 2 or three lifters in the set of 16. Last edited by Jay S; 05-26-2025 at 12:19 PM. |
| The Following 2 Users Say Thank You to Jay S For This Useful Post: | ||
Wow! I see that you have all the RAIV goodies already! I think they would be perfect in a '69 Firebird 400 clone! That combo would be 700 - 800 lbs. lighter than the GP alone in race weight, so 0.7 - 0.8 sec. quicker by weight savings.
Hopefully you have the D-port long branch manifolds for the GP. My brother built and dyno'd a '69 428HO engine (4-speed car) and with 10.5 to 1 compression and a Summit 2801 cam made 425 hp and 500 lb-ft torque, so would move a 4100 lb GP down the quarter mile in the mid-13's with ease. If I recall correctly, he needed to use flat top pistons (or less dish) to get the compression up with the 62 heads since their chambers cc's at 72 after resurfacing. Dennis |
Dennis |
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
| The Following User Says Thank You to ta man For This Useful Post: | ||
Dennis |
