Old 05-26-2025, 07:10 PM
Basically the 067 cam had 7 more degrees of exh duration and 1 degree less in overlap, and both had the same .406 valve lift.
So the 067 hung in there a little better above 4500 rpm with the stock exh manifolds.
Old 05-26-2025, 07:56 PM
Jay S's Avatar
Jay S Jay S is offline
In addition to the extra 7* of duration, the 067 also had the cam retarded 7* more than the 066. That worked so well for Pontiac that in 1978 for the 220HP 400s they used 067 grind again and retarded it another 5*, retarded 12* from a 066.
Old 05-27-2025, 09:51 AM
Seems like the 066 is better for a street 350 in my opinion.
The Following User Says Thank You to PontiacHO For This Useful Post:
Old 05-27-2025, 02:03 PM
Stan Weiss's Avatar
Unless the specs I have are wrong. It looks like while they have the same intake lobe, the 066 has the ICL 6 degree adanvced compared to the 067.
Stan
Pontiac Pump Gas List
