Old 05-26-2025, 12:58 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
And I was charged with removing a broken fender bolt, seeing I was the guilty party there!
The Following 4 Users Say Thank You to 7t4mula For This Useful Post:
Old 05-26-2025, 01:16 PM
Gator67's Avatar
Gator67 Gator67 is offline
I understand that you're trying to catch everyone up on your cool project, but exactly how far along you? The reason I ask is that folks might not chip in with ideas/suggestions about something if you're already beyond the point in the project where their input might be helpful.
Old 05-26-2025, 03:17 PM
7t4mula's Avatar
Very good point Gator67! I had posted a recent pic on “Let's see those pictures of '70 - '73 birds“ and it was suggested I start a build thread… forgot everyone else may not have seen this.
Body & paint are all complete, engine is built & almost ready to drop in. Working on fuel & brake lines soon here.
Interior work has started… just finished upholstery of buckets and carpet has arrived!
Old 05-27-2025, 02:21 AM
Current picture from the other thread.
It actually looks like it could pass for a Verdoro Green variant.
The Following 5 Users Say Thank You to Baron Von Zeppelin For This Useful Post:
Old 05-27-2025, 09:04 PM
7t4mula's Avatar
I would say it’s similar, but perhaps a hint more of bronze metallic hue to it?
Here’s the color chip that sold me that day at the paint shop! I also chose to go with satin bronze powdercoating on the wheels and other components (like grille surrounds) for accents. Turned out great I think!
ID:	652217   Click image for larger version
The Following 3 Users Say Thank You to 7t4mula For This Useful Post:
Old 05-27-2025, 09:24 PM
7t4mula's Avatar
The next pictures are from return from sand blast with subframe and rear axles. So incredibly clean!
Gotta get em costed quick, before they start to rust! Off to the paint booth we go!
ID:	652222   Click image for larger version
ID:	652223   Click image for larger version
Old 05-27-2025, 09:29 PM
7t4mula's Avatar
Jeff had made amazing progress already, having the underbody coated in satin chassis black and the trunk sprayed with textured black coating.
Busy spray booth there for sure!
ID:	652225   Click image for larger version
ID:	652226   Click image for larger version
ID:	652227   Click image for larger version
Old 05-28-2025, 10:05 PM
7t4mula's Avatar
Now things are starting to happen in my garage again also! Got the 12bolt back from rebuild, new posi unit with 3:73 gears! I don’t know if the dog was more exited than me? LOL
Nice to be able to blast and paint dozens of misc brackets, components and bolts for this as well! Helps keep costs down and makes you feel good about having a hand in it at the same time…
Decided to go with an aftermarket front valance, original had a load of bondo from kissing parking barriers I’m sure!
ID:	652255   Click image for larger version
ID:	652256   Click image for larger version
ID:	652257   Click image for larger version
Old 05-28-2025, 10:21 PM
7t4mula's Avatar
I bought a Willwood 4 wheel disc setup and it was pretty cool having that arrive! Feeling like Christmas again in Spring at this point!
I didn’t realize I had to modify the stock spindle units to mount calipers, but I made it work. Felt very fortunate to have guys back at the shop gladly step up, even after I’d retired from there! I mounted the units on wooden blocks to keep things square and make for safer cutting in bandsaw. I’ll follow soon with that assembly process with the new RideTech suspension system went with.
ID:	652259   Click image for larger version
ID:	652260   Click image for larger version
ID:	652261   Click image for larger version
ID:	652262   Click image for larger version
Old 05-30-2025, 08:37 PM
7t4mula's Avatar
Time for some serious suspension upgrades here! I purchased this package from RideTech and can’t wait to bolt it up to the subframe!
Started with the rear axle setup first. New Eaton springs and shackle/bushing kit from Energy Suspension.
ID:	652343   Click image for larger version
ID:	652344   Click image for larger version
ID:	652345   Click image for larger version
The Following User Says Thank You to 7t4mula For This Useful Post:
Old 05-30-2025, 08:45 PM
7t4mula's Avatar
These new control arms fit great and looked fantastic! Not really too difficult at all to do this assembly.
Started assembly of steering as well, but was still waiting for backordered Center link from Ride Tech. Mounted the new Borgeson steering box.
ID:	652347   Click image for larger version
ID:	652348   Click image for larger version
ID:	652349   Click image for larger version
ID:	652350   Click image for larger version
Old 05-30-2025, 08:58 PM
7t4mula's Avatar
The new Willwood, six piston front calipers and four piston rear calipers really looked amazing on there! I thought I was going to get shiny zinc coated rotors according to the catalog, but I actually really liked the look of these black ones!
You can see the area on the back of the front spindle that need to be modified in the third picture. They fit perfect!
Couldn’t admire them for too long, needed to break this down to be able to get the steel wheels back on there and roll them back on the trailer. The big front rotors especially were real close to the inside dia of that rim! Off to the paint shop to mount them back up on the chassis! Yes!
ID:	652353   Click image for larger version
ID:	652354   Click image for larger version
ID:	652355   Click image for larger version
ID:	652356   Click image for larger version
Old 05-30-2025, 11:29 PM
Cool stuff .
Your dog seems to have a lot of enthusiasm about the project too.
Always good to have some family support.
Old 05-31-2025, 09:37 AM
7t4mula's Avatar
Absolutely Baron! That hound is always hanging with me in the garage, sniffing around to see how things are going!
I cannot say enough for the family support on this project, my wife has often chipped in with me when I need an extra hand to hold something in place and that will come to light as I go through this. My grandson’s are beginning to get very excited about this coming together as well.
Old 05-31-2025, 12:37 PM
7t4mula's Avatar
Now it’s time to pick this Bird up off the perch and get her back on four wheels! So nice having a great lift like this to get everything in position.
ID:	652371   Click image for larger version
ID:	652372   Click image for larger version
ID:	652373   Click image for larger version
Old 05-31-2025, 12:43 PM
7t4mula's Avatar
Unbelievable, how bad a couple of the subframe bolts had rotted with water, apparently trapped around them in the bushing. Thankfully, all new hardware and bushing kit firmed that all up.
Bolt up the rear axle and springs and we’re ready to roll! Pretty cool to have it back together again and pushing it through the shop. Back on the casters and into the booth, to get set to mask and bag to get set for priming.
ID:	652375   Click image for larger version
ID:	652376   Click image for larger version
ID:	652377   Click image for larger version
The Following 2 Users Say Thank You to 7t4mula For This Useful Post:
Old 05-31-2025, 12:54 PM
Tommo99 Tommo99 is offline
Hi there, im just starting a rebuild on same car here in New Zealand, where did you guy your valance? are you happy with the quality?
  #38
Old 05-31-2025, 02:15 PM
7t4mula's Avatar
That cool! They are such great cars!
I’ll have to look when I get home, out of town for the weekend. I think it was Ames or perhaps Classic Industries.
Yes, very happy with the quality.
  #39
Old 05-31-2025, 08:58 PM
Thankyou, i will follow your thread for sure!
The Following User Says Thank You to Tommo99 For This Useful Post:
  #40
Old 06-01-2025, 11:25 PM
7t4mula's Avatar
About this time I was starting to finally crack into this 400 motor that I’d originally built back in the early 80s, it’d been sitting on a stand in the garage collecting dust since I pulled it from my ‘73 Formula about 20 years back!
It didn’t look bad at all, just needed some TLC. Time to tear it down and send to the shop for hot-tank and refresh. It had next to no miles in its original project home. That vehicle was just too badly rusted to finish restoring reasonably.
ID:	652460   Click image for larger version
ID:	652461   Click image for larger version
