Old 04-29-2025, 02:41 PM
X72GPX's Avatar
X72GPX X72GPX is offline
Send a message via AIM to X72GPX
Default Grill Loose
How can I secure the grill better, its loose.
Thank you
Old 05-03-2025, 07:38 PM
chiefpontiac66 chiefpontiac66 is offline
You can try snugging it down but be gentle. Those pins are fragile and can break right off.
Old 05-04-2025, 12:48 PM
X72GPX's Avatar
Thanks Chief, it’s a crappy system, yes the pins should be metal, not plastic……..
Maybe I’ll try electrical tape on the pin and see if that nut holds better.
Old 05-05-2025, 09:11 PM
I wonder if some of the black strip caulk would help snug it down without breaking the pin. Either way, let us know how things work out.
Old 05-06-2025, 07:09 AM
dataway's Avatar
dataway dataway is offline
If it does break off you can epoxy on something like an "elevator bolt" instead.
https://www.mcmaster.com/products/sc...ator-bolts-2~/
Old 06-10-2025, 09:13 PM
X72GPX's Avatar
I added a washer and snugged it down, lets see how long it holds...
Thanks!
