Old 07-11-2025, 10:40 AM
FrankieT/A's Avatar
Side note. Just out of curiosity, how are you handling the crank and cam sensor for your Terminator X?
The Following User Says Thank You to FrankieT/A For This Useful Post:
Old 07-11-2025, 11:43 AM
R 70 Judge's Avatar
Cam signal is handled by a Holley Dual-Sync distributor. Normally this would be fine for both the cam and crank signals, but I'm running individual coils and they weren't happy with the Holley signal. I added a Holley 12-1X crank trigger with hall effect sensor. I had a custom bracket made to use the Holley kit on a Pontiac.
Holley Dual-Sync: Part #565-207BK
https://www.holley.com/products/fuel...arts/565-207BK
Crank trigger: Holley 556-171 7-inch 12-1X Crank Trigger Kit, SBC
https://www.holley.com/products/part...8b7963aeb56668
Lots of info on my set-up here https://forums.maxperformanceinc.com...d.php?t=858788
ID:	654168   Click image for larger version
ID:	654169   Click image for larger version
James
1970 Trans Am
Old 07-11-2025, 04:08 PM
srmmmm's Avatar
srmmmm srmmmm is offline
A lot of the TA and TA/2 cars are running the lithium batteries too. Definitely less weight, but also less prone to vibration damage and more consistent voltage available through a wider charge range. This is the steering wheel dash in a 900HP TA Camaro during the warmup cycle. We take the oil temp to 130, do a leak check, header tube temperature check, and verify data collection before going out.
Lithium battery voltage rarely varies more than 0.1 volts.
Name:	TA Dashboard.jpg
The Following User Says Thank You to srmmmm For This Useful Post:
