Old 07-17-2025, 12:22 PM
grivera's Avatar
grivera grivera is offline
Originally Posted by Squidward View Post
This is with a long nose pump. There is a small gap…
…So the Lincoln Mark 8-ish fan is too thick for a 1st gen.
Since the first gen birds come with 4” (short) water pumps, would the OEM set up allow clearance for the fan?
Will Rivera
Old 07-17-2025, 01:46 PM
JLMounce JLMounce is offline
Originally Posted by GOAT8U2 View Post
I have this dual on my GTO, don't need 1 big one anymore.
https://a.co/d/fkWjTyZ
This is a copy of the Ramcharger fans from years ago I believe.
This is far too big for a first gen F-body. The core on these things is only 23" wide, and end tank to end tank is in the neighborhood of 28".
I would think so. I have the short water pump and use a Flex-A-Lite Black Magic fan. It's fairly deep and I have about 2" of room to the waterpump pully.
-Jason
1969 Pontiac Firebird
Old 07-17-2025, 11:46 PM
Squidward's Avatar
I used to run the short nose until the impeller started slipping and the seals went out. This was at the dragstrip. Racing was over, and a buddy drove me to Autozone for a replacement, which I was surprised they had. After that I went to a long nose (3/4" difference) and a deeper pulley to realign with crank/PS.
I considered a short nose pump, but as I tried test fitting everything, I would have to go short nose AND trim the shroud drastically, and/or mod the radiator mounting brackets. The Dorman version of the mk8 is just TOO thick.
Years ago, I had a Taurus fan on the bird. Interestingly enough, I had the OPPOSITE situation: When the fan was running at idle, it seemed to do better, but then I had creep at cruise and highway drives. I attributed this problem to the fan thinking it was blocking air at cruise. But I think now that it was more a result of running a poorly flowing thermostat that couldn't flow enough coolant when wide open. So I went SIMPLE: clutch fan and shroud, and I run the smallest wp pulley to maximize coolant flow AND fan speed. I enjoy playing with gizmos and gadgets, but I really do appreciate simple and reliable as best I can.
So here is why I am playing with an efan: Tired of getting a 34 lb rectal pucker every time I get stuck in traffic. Drive thru's are part of why we have these cool old cars, so I don't want to forego those. And I spent the money to put AC in this car, and I want to use it.
Data point: My 04 GMC 5.3 had a standard 28" radiator and clutch fan. With AC on and idling in a drive thru, it would creep to 220-ish or more. Putting it in neutral and giving it a rev to 2-3k for 5-10 seconds would bring it right back to 195 due to the increase in airflow and coolant flow. Interesting case in point: Heavy duty cooling option got you a 34" wide core. So I upgraded to a 34" radiator, even still using the shroud for the 28" core (I know, I know... it's on my list). It does better, but will still start to cook a little bit when it's 115+ out here. Never a problem at speed, tho.
Another interesting data point: In 2005 GM went to dual electric fans on their Sierra's and Silverados, and never looked back. A factory dual efan setup is a project on the horizon for my truck, unless I get a 2nd gen as a daily driver...
If I lived back in Michigan, I would likely think differently. I wouldn't care about AC so much, and cooling wouldn't be as much of a challenge. Just keep the windows down, and try not to swallow too many bugs.
The Following User Says Thank You to Squidward For This Useful Post:
