#1421
Old 04-11-2023, 09:58 AM
chrisp chrisp is offline
Originally Posted by mike202 View Post
Well I just went through this water pump swap trying to cool off my 1969 Grand Prix. Car is stock with AC, 428 and stock shroud and a new heavy duty fan clutch. I did install a 28" Griffin aluminum radiator and a 180° Mr Gasket thermostat.
Anyway, it always ran hot especially with the AC on. I just replaced the pump with a new cast impeller GMB pump and I hammered the divider plate to get about 1/"16" clearance. The old pump also had a cast impeller and had about 1/4" clearance to the plate.
Today driving at 75 mph with 93° ambient temperature, the engine coolant temp is 198° with AC off and about 210° with AC on. These numbers are unchanged compared to the old pump.
The motor is fresh so there is no issue with blocked coolant passages. I am running 70/30 water/coolant mix.
GM cast impeller has full vanes from hub hole to edge GMB does not . Was the 1 you removed full vanes close to the edge ? Add some more timing & fatten it up a bit & temps will drop.
The Following 2 Users Say Thank You to chrisp For This Useful Post:
  #1422
Old 08-12-2025, 11:52 AM
Hot Pontiac Hot Pontiac is offline
Thumbs up Chevy Waterpump on Pontiac Block?
Has any one Tried to Chevy Water pump(Big Block)Pump a Pontiac 389 OR 400 C.I.D. So I have been told going through all that work makes it work better are there any pics of it though or Vidio of it in actual motion?
The Following User Says Thank You to Hot Pontiac For This Useful Post:
