Your car looks great with either set of wheels on it. Maybe I'm weird but when I see those big wheels on 2nd gen F bodies, most of them just don't look good to me. It's the combination of the thin sidewall and how well it fills the opening. Also wondering about ride quality. As Formulabruce points out with a stock suspension it can be harsh. How do those feel to you?
It's important to note that this happens with leaf springs naturally. Because they are also an axle locator, they tend not to want to tilt. They do a minor amount due to compressibility of the bushings, flex in the shackles as well as in the leaf itself. It's not a lot though and as you take up that bit of tolerance, you get a rising spring rate and an axle that is picking up the inside tire. The CalTrac makes it worse. It's also why in many situations, leaf sprung cars don't run rear sway bars unless the springs are very soft or there is a very wide and sticky tire in the back. The CalTrac is of course adjustable and as the lower bar is leveled, it's effect is less. You could of course try a set and play around with them. You could leave them in their least effective state for most street driving and canyon carving, then drop the bar if you know you want to play around with hard acceleration runs. Really, the cure where leaf springs are concerned here is a leaf that can support the power you're making. You probably need more than a 200 lb rate and the leaf pack should be built so that the second leaf in the pack extends all the way to the eye and is banded there to help control spring wrap. It's probably gonna ride incredibly stiff though. Edit: An idea I've had in my head is to run a split mono leaf which a heavy enough front section to keep up with the amount of power and of course the lighter rear section to help with ride quality. This type of setup sucks as an axle locator though, so I would employ a watts link to take care of that. That's all theory though and I have no idea how that might actually play out. Considering the cost of a good split mono leaf and a watts, I'm not sure it's anything I'll ever try.
