Old 05-26-2025, 04:19 PM
Every 69 model year GM car was built with headrests.
Up to dec 31st 68 they showed on the invoice as a $16.85 option and if the customer insisted the dealer would remove them and credit the $16.85 charge. They even were supposed to install a GM kit that blocked the holes so kids wouldn’t get their fingers stuck..
As of Jan 1st production the base price of each car increased by $17 instead of charging for the option and it was no longer legal for dealers to remove them as they were now federally mandated.
Somewhere in my stash of parts I have an NOS bag with I believe 12 head rest hole blockers.
Old 05-26-2025, 05:10 PM
Might that be the reason there is no alpha-numeric code for the headrests on this window sticker . { A _ _ }
This is the one that 428ho4spd posted . Late'ish 1968 built.
Old 06-16-2025, 05:25 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
i'm curious what a rubber rear trunk matt looks like
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 06-16-2025, 06:41 PM
The rubber mat was an over the counter GM accessory.
Rectangle shaped and covered the bulk of trunk floor , had GM embossed on it.
Sort of like an anti-fatigue mat in a work area.
The Red 69 GTO Convertible that was on BaT last week had one in it.
Old 06-16-2025, 08:51 PM
Factory installed option also. Originals were dull grey. Ames does a repro but they are black. Interestingly they were available on all full and midsized cars but were clearly designed for the big cars so the fit poorly in a GTO but that’s how the factory made them, one size fits all.
The Following 2 Users Say Thank You to north For This Useful Post:
Old 07-07-2025, 09:37 PM
Here is one I have never seen pop up on a 69 GTO
55 Amp Alternator
S/R .... Solid state regulator maybe ?
Currently for sale on eBay.
Pretty sure this was formerly one of BLKBRD's cars in Florida.
Old 07-07-2025, 09:51 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Self Regulating Alternator, no separate voltage regulator on the firewall with this option.
The Following User Says Thank You to 428ho4spd For This Useful Post:
Old 07-07-2025, 10:35 PM
Yup, it was standard equipment on the 68 GP till the high failure rate made them cancel it. Then they tried it again as a standard feature on the 69 FB 400 but again high failure rate made them pull it again.
It was also offered on all 69’s as an option but only for narrow time windows.
The Following 3 Users Say Thank You to north For This Useful Post:
Old 07-07-2025, 10:46 PM
428ho4spd's Avatar
I've had a couple '69 GP's with them, but were slightly higher 61 amp units. They came standard with it if you had electric rear defog and ATC a/c as I recall.
Old 09-06-2025, 09:29 PM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
The Mayfair Maize 69 convertible in the 2009 photo is Mike Spizziris car. That was my first GTO in 1988 and he bought it a few years later from the kid that bought it from me.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming.
67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project.
Old 09-06-2025, 10:28 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
I have always wondered about mine..
1969 GTO convertible, Auto, Crystal Turquoise with....
AC, cruise control, fender turn signal lights, front disc, glove box trunk release, power driver seat, hood tach.
Some of that seems odd and not common for a convertible and 1969. Wish it had Ram Air IV.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
Old 09-11-2025, 12:47 PM
Diego, I’ll post the two-tone colors on those cars next time I look at my listing
Here you go:
ten cars:
8 cars had Cameo upper (Lower: 2 CT, 1 midnight grn, 2 matador, 1 Paladium, 1 Liberty, 1 Expresso
1 Starlight black top (Lower is CR-this car is a Judge)
1 limelight top (lower is midnight green)
I noticed most of them are Atlanta Arlington and Fremont cars, that with the Cameo white tops make me think this was a bit of a southern thing, vinyl tops dried up quickly in southern sunlight?
Btw, here is the picture of a factory installed accessory trunk mat from my Bonneville convertible. The hole that looks hand cut is factory because it is a convertible, there is a cutout pattern on the back side of the mat.
ID:	656965   Click image for larger version
Old 09-11-2025, 12:53 PM
Found a picture of the back, the cut out hole must have been for the Bonneville since the other hole outline is for the six inch shorter Catalina trunkpan. Since the cutout hole that was cut is larger I wonder if it said Bonneville and Tempest? There is no other reason the hole would have been bigger since all A and B convertibles used the same sized tiedown bracket.
Old 09-11-2025, 03:27 PM
Diego Diego is offline
Much appreciated!
I’ve seen a green/green car as you describe.
